Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
confusing property names do not match names in schema file
3 REPLIES 3
BurkhardRammner
162 Views, 3 Replies
as inputs for my bifrost graph, I have radius and color array data.
Why is it that in order to render the radius of points (as disks) I can add the property 'point_size', but when I want to render the correct color, I have to add the property 'color', instead of 'point_color'?
Both properties are mentioned in the 'points.json' file as 'point_size'/'point_color'.
What am I getting wrong?
thanks
3 REPLIES 3
sepu6
in reply to: BurkhardRammner
You can render both it doesn't matter how you call the property, The important part is how you read it when you want to render it and make sure is a vector 3 if you want color. I can render either color or point color using user data nodes hypershade or set geo property reference in BF - Post an example scene.
BurkhardRammner
in reply to: sepu6
Sepu,
I ment viewport render, not arnold render.   Cannot post an example scene easily, as the bf input node is a custom node.
It is of bf vector array type and setting the data to type 'color'  make the color data show up nicely in the viewport. Does not work when type is 'point_color'.
sepu6
Yes that is a Maya thing If Im not mistaken. That is the only one as far as I remember that you have to do that.
