Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
change property for point shape
2 REPLIES 2
andrea_pinto82
317 Views, 2 Replies
Hi everyone
What the right way to set color,trasparency or setDepthPriority for a point shape?
I tried to use set_geo_property, it works little bit.
there is some problem to update the shape in the viewport.
I have the result when switch on/off the screen aligned.
any ideas?
thank you
Andrea
here when I change the color or transparency of the quad and it become fill
quad change transparencyquad change transparency
and then the result when I switch the screen aligned
quad updatequad update
2 REPLIES 2
ikerclon
in reply to: andrea_pinto82
I'm not sure if it's related to your case, but when I was setting the color attribute of a geometry using RGBA values, it seems there was some Z-fighting issues in the viewport. It looks like it's resolved in recent Bifrost updates, but just in case, here's a workaround:
- Select an alternative Transparency Algorithm on the Viewport 2.0 properties (Depth Peeling or Alpha Cut).
andrea_pinto82
in reply to: ikerclon
Thanks for reply.
I am using a point shape and the problem is to update the transparency.
I don't know why that happens.
I think I'll fall back to use the circle shape without transparency to convenience.
update transparencyupdate transparency
