Cant cache via Compute & Cache to disk
I'm trying to cache a sim but it says i have no containers selected even though my "cigarette smoke" container is selected.
"// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2022/2.2.1.0/bifrost/scripts/getBifrostObjectsToCache.mel line 52: Must select Bifrost containers to cache the data."
You can create a user cache for an individual Bifrost object by setting its Caching attributes. Caching a single object reduces unnecessary computations when user caches of other objects in the simulation are not needed. This means that you need to recache the entire simulation if you extend its frame range.
- Select the main container for the simulation that you want to cache.
- In the Attribute Editor, click the tab for the main properties node of the object you want to cache.
- In the object's Caching group, set Cache Control to 2 (write mode).
Make sure that all other Caching attributes are set as desired. See Bifrost Caching Attributes.
- Play the simulation from the start frame to create the user cache.
Bifröst computes and caches frames for the object and saves them to the specified location.
- Set the Cache Control to 1 (read mode).
- Preview the simulation."
I don't seem to have cache in my attributes either
