Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
can't load bifrost from mounted location
1 REPLY 1
froszu
111 Views, 1 Reply
I have bifrost installed in a shared folder that is mounted on local computer (CentOS).
When I load plugin in maya, I am getting these errors:
Error: line 1: Error: Failed to locate Json doc 'bifrost://bbcfg/pkgs/prod/bifrost/2.5.1.0/linux64_2022/bifrost/resources/plugin_config.json'.
Error: line 1: Error: Failed to locate Json doc 'bifrost://bbcfg/pkgs/prod/bifrost/2.5.1.0/linux64_2022/bifrost/packs/packs_plugin_config.json'.
Those files are accessible and readable/writable. Also the owner is the same user as the maya user.
If I copy bifrost folder to local disk then all is OK. I would much preffer keeping bifrost on a separate server.
Any hints ?
1 REPLY 1
froszu
in reply to: froszu
Some more datails.
The actual mountpoint is /mnt/bbcfg/pkgs and it is symlinked with
ln -s /mnt/bbcfg/pkgs /bbcfg/pkgs
Loading bifrost directly from /mnt/... (so a mounted shared folder without symlink) works OK, but not from a symlinked path.
I know that under linux (for example with some python operations) symlinked paths can expand to real paths and that is something that might break bifrost installation. Seems like a bug to me ?
