Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Can particles be changed to images?
2 REPLIES 2
kyororin8732
162 Views, 2 Replies
Is it possible to replace particles with images and emit them? For example, I want to change the shape of the particle to a star image so that the star appears instead of the circle. Is there any way?
2 REPLIES 2
Roland.Reyer
in reply to: kyororin8732
Did you try instancing?
node "create_instances"
plug the particles into "create_instances.points"
plug the desired shape into "create_instances.instance_geometries"
The orientation is a problem, though.
kyororin8732
in reply to: Roland.Reyer
thank you for answering! I learned about instantiation for the first time. I am very happy to get the expected results! thank you!
