Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost version 2.0.1.1 / file_cache node / Alembic export -> 1 Ko
3 REPLIES 3
moiamy
688 Views, 3 Replies
Hello
File_cache node works with Bob & Vdb.
It produces just a 1Ko file with Alembic.
ABC plugin export version : 1.0
Any idea ?
Fransua
Tags (2)
3 REPLIES 3
Alembic can only be used to export meshes at the moment. Therefore, it doesn't make sense to use the file_cache node to export Alembic directly from Aero, for instance.
Hello Morten
I was able to export Bifrost Liquid with Alembic.
Does it mean it doesn't work with Bifrost aero or with simulate_aero inside Bifrost Graph ?
joostkonemann
in reply to: moiamy
As Morten wrote, Alembic currently only works with meshes, so if you don't feed the write_alembic node a mesh, it will not work.
With Bifrost Liquid, you probably enabled meshing in the liquidShape node and wrote the resulting mesh to Alembic.
For Aero sims, use the native bob file cache or openVDB if you want to render the volumes with other renderers than Arnold.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
