Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost Particles float above the collider
2 REPLIES 2
178 Views, 2 Replies
I'm working on learning to do an MPM snow sim but am having this issue where the simulation floats slightly above the collider. I've tried adjusting the detail size on both the simulation and the collider but this issue still persists. Capture.PNG
2 REPLIES 2
sepu6
A couple of things, on the MPM solver, uncheck `link collider detail` since you want to drive this through the collider itself.
in the collider change the resolution mode from relative to absolute which will give you a more accurate representation of your collision geo. It will be more expensive but is more accurate.
Also, think about how far or close your shot will be. if your camera is pretty far away you have you probably won't be able to tell that small offset that you have, and you will save a lot of time.
in reply to: sepu6
This fixed it. Thank you so much!
