Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost not working
9 REPLIES 9
Message 1 of 10
fatjulio
3316 Views, 9 Replies
Bifrost not working
I've just installed Maya 2019.2 to have a play with the new Bifrost. The menu's are all there, plugins all loaded. When I open a demo scene, say the steamy_breath, it loads all the geo and bifrost graph. When I press play, nothing happens. The play bar goes round and round without doing any calculations. In the output window there are 4 errors which keep repeating:
Error: while compiling top level compound 'steamy_breath1', around :
JIT compilation used external function 'sqrtf' which could not be resolved
JIT compilation used external function 'cosf' which could not be resolved
JIT compilation used external function 'sinf' which could not be resolved
JIT compilation used external function 'atan2f' which could not be resolved
The computer is windows 10 upgraded from 7, all updated. The system drive is 😧 as opposed to C:, because of a change in system drives a few years ago. I don't know if any of that would influence anything.
Thanks.
9 REPLIES 9
Message 2 of 10
rkovach
in reply to: fatjulio
I can't get BiFrost to work either, although I get different error messages.
Tried Maya 2018.6 and Maya 2019.2, neither work.
When opening a Sample File I get errors related to unknown attribute types.
When I try to create a simple particle system and play it back I just get this error over and over:
// Warning: Cannot draw an object with no points. //
Message 3 of 10
WindXu
Thanks a lot for reporting to us. But I haven't been able to reproduce it on my end. Example bifrost graph "steamy_breath" works as expected for me.
To help us locate the problem quickly, could you please do some quick tests for us?
Test 1:
1) Create a bifrost graph
2) Tab and type "square_root" to create a square_root node
3) Select the node and set the value as "16" in parameter editor
4) In script editor run command: getAttr bifrostGraph1.root
If the node works, it should return number 4.
Test 2:
Based on the errors, it seems Bifrost cannot find math lib on your windows. Could you please go to your Bifrost install folder and open Autodesk\Bifrost\Maya2019\2.0.1.0\bifrost\resources\amino_config.json
You should see meta data as below:
"files": [
"ucrtbase"
"path": "C:/Windows/System32"
Is it C: drive in your config file? If yes, change C to your system drive letter, restart maya and see whether it works or not.
Message 4 of 10
fatjulio
in reply to: WindXu
Thanks. It was the the amino_config.json file pointing to C: when it should have been D
Message 5 of 10
WindXu
@fatjulio  Thanks for confirmation and I am glad it works for you now. I have logged BIFROST-3325 for this problem.
Message 6 of 10
tina.sauser
in reply to: WindXu
What if it is the same problem on a mac.
Screen Shot 2020-01-13 at 11.20.21 AM.pngScreen Shot 2020-01-13 at 11.20.29 AM.png
Message 7 of 10
WindXu
in reply to: tina.sauser
Hi Tina,
What Bifrost version are you using and what errors are returned on your side?
The issue talked above is specific to Windows as far as I know.
Message 8 of 10
tina.sauser
in reply to: WindXu
It appears that on our Macs we are having the same issue as reported on the
PC. Maybe a path or folder issue???
Bifrost version is 2.0.4
Mac OS version 10.13.6
My student is watching the Maya Learning Channel video titled Creating a
Smoke Trail in the Bifrost graph. He is trying to recreate the scene where
the rocket has a smoke trail. When he adds the smoke trail to the square
parented to the rocket and hits play, he gets nothing for smoke and an
error in the playback with no code attached.
[image: Screen Shot 2020-01-13 at 11.20.21 AM.png]
[image: Screen Shot 2020-01-13 at 11.20.29 AM.png]
Message 9 of 10
tina.sauser
in reply to: WindXu
It appears that on our Macs we are having the same issue as reported on the PC.  Maybe a path or folder issue???
My student is watching the Maya Learning Channel video titled Creating a Smoke Trail in the Bifrost graph.  He is trying to recreate the scene where the rocket has a smoke trail.  When he adds the smoke trail to the square parented to the rocket and hits play, he gets nothing for smoke and an error in the playback with no code attached.
Message 10 of 10
tina.sauser
When we go in to add the BiFrost premade Trilobod crash, we get a yellow flag at the bottom of the screen about the cache and now it is freezing the computer.  We get the spinning wheel.
