Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost MJCG extrude strands doesn't work
6 REPLIES 6
daniel.jankolovski
548 Views, 6 Replies
I am following a tutorial from Maya Guy on youtube. He plugs create_particle_trails in extrude_strands, but when i repeat the process i just get the curves of the trails just like the node does not exists. Any tips ?
Labels (3)
6 REPLIES 6
mjcg91
in reply to: daniel.jankolovski
This is an old version of the compound, which requires the strands orientation to be computed before.
Please update to the latest version of MJCG compounds. extrude_strands can be directly on strands and is faster.
https://gumroad.com/l/mjcg_compounds_2_0_0
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
daniel.jankolovski
in reply to: mjcg91
Thank you ! that worked like a charm.
daniel.jankolovski
in reply to: mjcg91
Hi, I've hit another roadblock regarding the same extruded strands. They are not appearing in the render, what am i missing ? @mjcg91
mjcg91
Hmm, Difficult to say without having more informations. The other mesh seems to render fine so the Arnold version should be compatible.
are there any error / warning in the render logs? Can you share a simple repro scene?
daniel.jankolovski
in reply to: mjcg91
I think i found what the problem is although i'm not sure what is happening since i just stared using bifrost. When i uncheck Spatial Resample in resample_strands it show up in the render. Is there a way around it ?
Edit : There were no errors
mjcg91
I'm not sure what's going on. perhaps two successive points share the same positions in the strands. This would impact the basis vector generation of the strands and could potential fails.
I'd just leave Spatial resampling OFF. or you could use a second resample node with spatial resampling ON. maybe it should fix it.
