Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
bifrost liquid particles
9 REPLIES 9
Message 1 of 10
consrojo
821 Views, 9 Replies
im working on a bifrost liquid particles, i need to get my particles closer to the boat, how can i do that? im using the boat as a region emission, as a collider and have a boss ocean hide using it as a guide.
tks in advance.
9 REPLIES 9
Message 2 of 10
consrojo
in reply to: consrojo
nobody? i just need to set up the particle system closer to the boat, any advice?
tks in advance.
Message 3 of 10
michael_nielsen
Sorry for the delay in responding.
Try to adjust the thickness on the collider as shown in the attached image.
Hope this helps.
Cheers,
Michael
Michael Nielsen
Principal Engineer
Message 4 of 10
consrojo
in reply to: michael_nielsen
tks for the answer, it works, just disabling the cache, i was changing the options without disabling the cache, so it wasnt showing the changes.
tks mate.
Message 5 of 10
consrojo
tks for the answer again, now i got this artifacts, the upper bifrost liquid particle is being guided by the boss, but when i render the bifrost liquid i got those artifacts, i think that those are fluid s settings but dunno how can i improve them, the liquid is taking strokes shapes in the end of it and it doesnt get a solid shape.
any advice? tks in advance.
Message 6 of 10
consrojo
this is the bifrost liquid particles result, by the way is there a way to avoid having particles inside the boat? or do i have to do a separate renders to get that?
Message 7 of 10
suryamunny
create a mesh surrounding liquid inside boat. now select bifrost and the mesh created for deleting and create killfield from bifrost fluids menu.
Message 8 of 10
consrojo
in reply to: suryamunny
tks for the answer, that boat has a dynamic locator, you are saying that create a mesh, could it be the same mesh, the boat one, or do i need to create a new one? i have a low poly boat, can i use that one?
tks in advance.
Message 9 of 10
suryamunny
Its better to create a new mesh and make sure not to use hollow mesh.
Message 10 of 10
consrojo
ok, gonna do that, right now im rendering the particles, not using primary visibility to give the particles the reflection of the boat but when i use that i get this, those are the boats shape, how can i render that without getting that boat shape?
tks in advance.
