Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost liquid alembic export problem
12 REPLIES 12
Message 1 of 13
thedanwright
383 Views, 12 Replies
Hello people,
I've been getting this nasty result every time I create an alembic export file from a Bifrost liquid animation, it's seems to only be when it's an emitter inside a collider, a liquid in a bottle or glass. I created a simpler version and the results were the same, sometimes the mesh smooths out as it should be, this test did at frame 49.
I'm using standard settings on the collider and emitter, I've also played with voxel density, no change. It reminds me a bit of when you sometimes run a displacement with too many iterations and it sends vertices in all directions.
Any ideas?
12 REPLIES 12
Message 2 of 13
thedanwright
in reply to: thedanwright
This may be only in the latest version of Maya and Bifrost as I tried it in Maya 2024 with Bifrost version 2.7.1.1 and the resulting mesh was fine.
Message 3 of 13
sepu6
is this liquid coming from the graph? the mpm fluid?
Message 4 of 13
thedanwright
Bifrost liquid and collider options applied to existing meshes from the Bifrost menu, not using the graph to set it up so not using MPM.
Message 5 of 13
thedanwright
It's also just done it on the latest export from Maya 2024, it's fine for the first frame, goes haywire but retains the rough shape but with vertices firing off along the surface everywhere then returns to normal after a further 60 or so frames, it's weird.
Message 6 of 13
sepu6
can you post the file. Not sure without looking at the scene.
Message 7 of 13
thedanwright
in reply to: sepu6
Sure, this one causes the issue in both Maya 24 and 25.
Message 8 of 13
sepu6
Save the pts as .bif from the menu.
Then load them in the graph and do the meshing there and save them as an alembic as well from there.
Doing it from the graph is a lot better.
Message 9 of 13
thedanwright
Thanks very much
Message 10 of 13
thedanwright
Turns out using cached playback causes the issue with legacy Bifrost liquid.
Message 11 of 13
thedanwright
in reply to: sepu6
Any ideas how I can get the liquid to 'stick' to the walls of the collider (bottle) as it would do in real life? Right now it's lumping a bit lower down.
Message 12 of 13
sepu6
that is what the resolution is for, so lower your voxel size. Keep in mind that it will make your sim slower.
Message 13 of 13
thedanwright
I'm playing about with lowering it and playing with the bifrost meshing settings to avoid it over-smoothing the angles, not managed it yet but will persevere.
