Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
bifrost graph i want aero collide inside sphere
4 REPLIES 4
marcury
539 Views, 4 Replies
just trying reverse normals but nothing works , emitting smoke and i want collide inside a sphere
4 REPLIES 4
joostkonemann
in reply to: marcury
Use a sphere with thickness... So just extrude the entire sphere.
Default settings for the collider will work... See video.
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
Another option you can use (if you don't want to extrude anything) is simply set the collider to "shell mode" instead of "solid mode".  Then specify a thickness for the shell - all can be done on the collider node.
marcury
in reply to: joostkonemann
this extrude was the logical solution but when the collider shell option didnt work i felt totally frustrated and didnt think about extrude 🙂
marcury
in reply to: marcus.nordenstam
unless i did something wrong , this shell mode with thickness was my first solution and  didnt work , but with the extrude thing is ok
