Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost fluid cooling fire (aero)
2 REPLIES 2
teddude75
560 Views, 2 Replies
Is it possible to get the point position of a bif object (fluid water) to lower the temperature of aero solver. For example, a house on fire and a hose spraying water onto it lower the temperature. How could I make that work?
2 REPLIES 2
stamatk
in reply to: teddude75
Hi @teddude75
One way to do this is to export the liquid mesh and read it back into the bifrost graph.  You can then use this mesh as a mask for a modifier influence:
- Get a modifier influence and set the property to voxel_temperature or voxel_gas_oxygen
- Use the replace mode with a high rate
- Plug a mask_influence chained to the modifier_influence
- Plug your mesh to the geometry port of the mask_influence.  Make sure to set the shape to mesh and adjust the voxel size accordingly.
I have attached a video of this effect.
Hope this helps,
Thanks!
Konstantinos Stamatelos
Bifrost FX Product Owner and Designer
teddude75
in reply to: stamatk
Yeah that worked. Thanks for the help. Is there also a to animate vertex color set and drives the temperature? Does color sets work with fire?
Technology Administrators
