BiFrost/Arnold Render Issue
Message 1 of 14
Dear Forumers,
I have a 380 frame scene with bifrost liquid and foam and some nparticles and various geometry.
I want to render frames 210-380 to check something.
My problem is every single frame thats rendered seems to need to be stepped up frame by frame from frame 1!!!
Needless to say this is slowing down my rendering painfully.
How can I fix this?
Nick
Replies (13)
Message 2 of 14
teddude75
Make sure that all simulations are cached.
Message 3 of 14
they are cached
Message 4 of 14
Christoph_Schaedl
Are you using the cache node in read mode?
Or do you have written out a VDB?
https://linktr.ee/cg_oglu
Message 5 of 14
i have not written out VDB.
i have clicked on "compute and cache to disk" from the bifrost menu
Message 6 of 14
Christoph_Schaedl
Are you using the old Bifrost?
Follow this tutorial.
https://youtu.be/4jDeRVBTpGg
Message 7 of 14
yes the old one
Message 8 of 14
teddude75
"stepped up frame by frame from frame 1" I'm pretty sure that means your simulation is not cached to disk.Make sure that all simulation are reading from the disk drive and not simulating for each frame. If you did it right you should be able to skip frames and scrub the time line seeing the simulation. If you can't scrub the time line than you didn't cache (not scratch cache) to disk. Also nparticle use ncahce. Make sure that's reading from disk.
Message 9 of 14
no the thing is i can scrub both the particles and bifrost. they are cached. thats the weird problem!
Message 10 of 14
teddude75
It sounds like a rendering issue. Did you set your frame range in the render settings? Also you can offset the cache files to start at frame 1 (I don't know it that would help). But for the most part, rendering water, foam, and nparticles is pretty heavy on the renderer. What kind of system are you running? Is it possible to separate the Bifrost and nparticles with render layers?
Message 11 of 14
It happens whether its a frame range or a single frame.
Dunno why you suggesting offsetting cache files. And they start at frame 1 anyway.
I have a very good system and need to render them all together anyway as the nparticles are within the bifrost fluid so need to be rendered as refracted.
Currently I'm having another CRITICAL issue anyway:
https://forums.autodesk.com/t5/maya-shading-lighting-and/arnold-nparticles-render-problem/m-p/898794...
so its all academic at this point 😞
Message 12 of 14
teddude75
It's really kind of vague the issues your having.I would check your render log if your have rendering issue. I ran into a problem with particle render in transparent water but that was a couple years ago.(min pixel width fixed that) Can you give me more information about your scene. Maybe send an image or a scene file?
Message 13 of 14
i'm sorry. don't know how to be more specific. thanks for trying to help, i'll attach scene file here. the major issue is the hanging atm anyway.
Message 14 of 14
matthewGNQTJ
Did you ever get a solution to this? I am having a problem very similar to what you described
