Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Arnold volume material not showing up on MPM particles
26 REPLIES 26
Message 1 of 27
davide445
1043 Views, 26 Replies
Trying to render my particles trough an aiStandardVolume material
The result show always the standard Lambert material
As far as I know the default material cannot be removed, and need to be automatically superseded from the assigned volumetric material.
26 REPLIES 26
Message 2 of 27
Stephen.Blair
in reply to: davide445
I think you have to give the particles a non-zero step size
https://docs.arnoldrenderer.com/x/TBJSAw
// Stephen Blair
// Arnold Renderer Support
Message 3 of 27
davide445
in reply to: Stephen.Blair
A bit lost. Didn't find where in fact to assign step size.
Using set_Arnold_volume_settings node didn't change the behavior
Setting the volume material directly in the viewport seems to bypass Bifrost and change something, but again didn't find where in fact to set this parameter.
Message 4 of 27
mspeer
Hi!
You need to insert set_Arnold_volume_settings into your existing network, so insert it before or after assign_material and then set Step Size to a value > 0.
You also need to connect the aiStandardVolume1 material to the "surface material" input.
Message 5 of 27
davide445
davide445_0-1635246126515.pngdavide445_1-1635246182090.pngdavide445_2-1635246224132.png
@mspeerapart this got the same result also connecting simulate_mpm:volume to set_Arnold_volume_settings:volume
Message 6 of 27
mspeer
Hi!
That's not what I suggested, maybe I better show a screenshot.
Message 7 of 27
davide445
in reply to: mspeer
With your same parameters, standard volume settings in Hypershade
Result
In outliner bifrost node it's still associated with Lambert material, not sure if this is correct
Also I'm doing MPM snow sim, not sure if this need to change something.
Message 8 of 27
mspeer
Hi!
Delete the lambert2 material and then try rendering again.
What Maya and Bifrost version are you using?
Please provide a scene-file for further help.
Message 9 of 27
Bruce.Lee.
I think this is a very serious bug. Moreover, this bug has been there for the last year. The volumetric material of particles in the Bifrsot diagram cannot be rendered correctly. The solution is to give Maya's DAG node volume material.
Message 10 of 27
davide445
@mspeerLambert seems to be the default material assigned to every asset so removing it produce this result
Using Masya 2022.2 and Bifrost 2.3.0, updating to 2.3.1 result the same.
Looking at bif14 associated initialShadingGroup I didn't see any volume shader or material, not sure if this is correct and all need to be managed trough Bifrost, I have already tried here to remove the lambert and add a volume but with no results, maybe I'm doing it wrong.
Attached a demo scene, stim start at frame 1.
@Bruce.Lee.Not sure what you mean with "give Maya's DAG node volume material", if it's something I can do in my scene or it's an Autodesk task.
Message 11 of 27
Stephen.Blair
The MPM snow throw example.
In the Arnold Render View:
  • On the right, particles rendered with a utility shader
  • On the left, particles rendered as volumes (by setting the step size)
// Stephen Blair
Message 12 of 27
Bruce.Lee.
Maybe this is where the bug is. I have not tried to connect the volume material to the surface_material port. The volume material should be connected to the volume_material port. When connected to the volume_material port, the rendering is white.
Message 13 of 27
syracoj
Aslan reminded/said points_to_volume should work. I tried it. Is this what you need?
Message 14 of 27
mspeer
Hi!
Here are multiple solutions:
1) (Recommended) Just connect again "lambert1" to the Surface Shader input of "initialShadingGroup".
Then it works, cause lambert1 can be overridden, but lambert2 not.
2) An other option would be to break the connection between any Bifrost node and the initialShadingGroup in Node Editor.
I also would recommend to convert the older graph to the newer format by using
Edit -> Convert Graph
Message 15 of 27
davide445
@syracojin this way works in the viewport using standard aero preset, increasing the desnity and setting emission in density channel
but didn't work in Arnol render
The goal is having something like this, produced using fog shader with increased density (in Houdni). If nothing else work (but suppose there will be a way) an option will be export the sim in vdb and render in Houdini.
@mspeernot sure why this approach works, if your approach is more "regular" will try this also
Message 16 of 27
mspeer
Hi!
The problem in your scene is that you changed the default material connections in Maya.
If you revert this to the default setup my solution will work.
That's all you would need to do in your scene to make it work with your current graph.
Message 17 of 27
Stephen.Blair
in reply to: Bruce.Lee.
Yeah, a bug.
On the one hand, Arnold doesn't have a surface port and a volume port. It's just one shader port, and you can connect whatever...a surface or a volume.
But on the other hand, for usability, the translator should take care of it. I mean, we already do that for the shadingGroup node in regular Maya.
When you connect something to the volume port, no shader is applied to the object (by the time it gets to Arnold).
// Stephen Blair
Message 18 of 27
davide445
in reply to: mspeer
In my complete project I didn't find in Hypershade the nodes you show, this is what I got, probably the result of my many attempts without really knowing what I'm doing
Message 19 of 27
davide445
in reply to: syracoj
Regarding the point to volume solution I tried to increase the fog density from 1 to 10 but still got this wrong rendered color
This is the last problem I'm facing, will be good having a hint if something is wrong i.e. in my standard volume shader settings
Message 20 of 27
Bruce.Lee.
There are two ways to solve this problem. One is to directly assign materials to nodes in accordance with Maya's material flow. The second is to import the material into the node graph according to Bifrost's process.
