Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Advect points(non-particles) by aero sim?
5 REPLIES 5
darioOrtisi
548 Views, 5 Replies
Hello. Is there a way to advect point by aero?
5 REPLIES 5
Hi, I dont know if we can do that with static points right now, but with particles is so easy. Just use Volume Influence and connect it to the aero sim. Use a Drag Influence with high value on the particles too for this technique.
Best
Sorry, my read capacity of your title ( non-particles ) has been zero, xd. Avoid my reply.
mjcg91
in reply to: darioOrtisi
If you don't want to use simulate_particles, it it possible with a sample_volume_vector, but if you want continuous emission you'll have to use a feedback port, which will basically simulate points... IMO The easiest way is by simulating particles with the built_in nodes. here's what you can do:
_Use the same source geometry as the one used on aero.
_Turn of gravity and other forces like normal force.
_Use the output aero volume and feed this into a volume influence, with force_scale = 1.0
_Add a drag influence and set a very high value like 100,000.
_Enjoy
EDIT: Juanjo beat me to it 🙂
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
darioOrtisi
in reply to: mjcg91
Thanks @mjcg91  as ever.
I will like to do this.
https://youtu.be/2zb1AuMiBN0
Finger  cross
miguelsoler30
in reply to: mjcg91
Hi, so one question, if i have the particle simulation how i advect that? or need a aero simulation too? would have to use advect_field??
thx
