Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Add custom velocity to Static object?
3 REPLIES 3
darioOrtisi
325 Views, 3 Replies
Hello everybody.
Bifrost graph. There is a way to take point normal(direction) and convert to custom velocity? Assign a force that take a value and just in case randomize the value?
3 REPLIES 3
darioOrtisi
in reply to: darioOrtisi
Ok. I taked it.
sepu6
Couldn't just you grab the point normal > add noise > set geo properties to "point_velocity"
I believe that should work. Unless I misunderstand what you want.
darioOrtisi
in reply to: sepu6
Hi.
I just did it get_normal_from_point, add multiply, connect the previous get_normal to multiply , add a value to the multiply and set the value, Output from multiply to set_point_velocity \velocities(input) and the output to a source air with no density.
