Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Access to number of inputs?
2 REPLIES 2
valhallen
340 Views, 2 Replies
Is there some way I can dynamically change a node in a compound based on inputs to that compound?  This is an interest thing, and I realise I can probably python something up based on selection, but just wondering if there's access to the input counts inside the graph?
Not sure if I have explained it very well, but I'm sure you get what I'm talking about - it's a simple switch node using an array on the inside of the compound and I'm probably running before I can walk, or there's something already existing that I have breezed right past (likely), but would be nice to have.
Tags (3)
Labels (1)
2 REPLIES 2
mjcg91
in reply to: valhallen
you can do it easily. Instead of your many inputs, create a port with type array<Amino:Object>. Then from the outside of your compound, right-click on the port and check "Fan-In". The port icon will change and it will act the same as if you were using build_array.
http://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_build_a_graph_work_with_arrays_html
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
valhallen
in reply to: mjcg91
Awesome.  Thanks again 🙂
Technology Administrators
