In the latest HSMWorks development release we have added support for No Drag for Turning Profile implemented by Alexander. This feature will allow the cutting direction to be automatically adjusted to avoid the insert dragging "up" the walls. This is one of the top feature requests for turning.
You need to enable beta mode to see the feature.
For now you will only see a single setting on the Passes tab called "No dragging" which is disabled by default.
A normal Turning Profile toolpath would drag the insert up the wall:
With no dragging enabled the toolpath will be automatically split and relinked to ensure the insert cuts "toward" the stock.
For now the no dragging applies to both finishing and roughing passes.
The point of split is taken from an advanced parameter called No Drag Limit which is currently only available from the Compare and Edit dialog. The No Drag Limit is an angle measured from the "vertical" insert cutting edge to the toolpath tangent. The default is 22.5 deg.
Here is a simplified toolpath with only finishing passes. No Drag Limit of 22.5 deg.
And here is the same toolpath with No Drag Limit of 60 deg.
There is currently no overlap supported but this will be added a bit later. Also not there is a small clearance to the stock "wall" that is currently proportional to the tolerance - this will only be visible at near "vertical" walls. We didn´t expose this setting yet because we didn´t have to good default for it.
Please try it out and let us know if you see any problems. Thanks.
First of all this is awesome!
Indeed overlap would be needed for finishing passes especially. So for now it doesn't really help much for finishing where it would give most advantage.
The clearance default I would suggest is the nose radius, but would love to be able to edit this value. Especially for roughing in stainless this would make the insert last 2 times as long if I could stay clear at least 2 mm from the wall.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
New development release now available with a few fixes for No Drag. I also added the clearance feature now.
René
I have reported that the No Drag cannot be turned off on ticket CAM-4384
Was just coming back to this to report. I do not have Beta mode enabled.
I even send a video to the guys.
Laurens Wijnschenk
3DTechDraw
René for Legend.
I'm just not that cool.
FYI here's my Compare and Edit for that toolpath:
Hey guys,
Thank you for reporting.
In the meantime, I am excited to get your feedback on this feature.
Cheers,
Al
@al.whatmough wrote:
Hey guys,
Cheers,
Al
The feature it's self has just proven to make my insert survive 20 minutes instead of 8 min in stainless roughing.
So what do you think? AWESOME!
(I expected 2 times due to previous hand written tests but it turned out to be more for this specific case.)
For the finishing I haven't tried because these parts need to be spot on and since there is no overlap I know there will be a little mark. But once that has been fixed it will be perfect for finishing making sure you get small chips instead of very long ones.
Laurens Wijnschenk
3DTechDraw
René for Legend.
@Laurens-3DTechDraw that is great to hear.
Alexandar will he pumped to hear this. He works hard on this one for a while!
It is always motivational for devlopers to see their code saving customers $$.
Cheers,
Al
A welcome addition to the Turning, GOOD JOB!
We typically use this strategy for finishing and have been very happy with it. Standard Roughing with a CNMG and Finishing with a VNMG using the No Drag strategy is poetery in motion. Haven't seen a need for it in Roughing but it is good that others are enjoying success with it.
I'll explain why this is helpfull for roughing as well.(Especially with WNMG and CNMG inserts due to the angle they are commonly used in.)
When you have the chip breaking on the side of the tool, the chip will get trapped between the insert and the side wall.
When this happens you get forces on the insert where they aren't supposed to be and possibly break it. So with this you can make sure that doesn't happen.
Laurens Wijnschenk
3DTechDraw
René for Legend.
excellent feature!! Any chance of getting pull away from vertical walls before retract in the grooving and parting toolpaths soon please? Then you can allow rapid retract too.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
@Laurens-3DTechDraw should be soon now 🙂
Alexander has been hard a work!
