DWG Trueview 2022
DWG Trueview 2022
bgraham247
DWG Trueview 2022
bgraham247
Has anyone had luck with editing the dwgviewr.msi file for DWG Trueview 2022?  Trying to add some paths in the "Property" tables as I have for years.  After edits are made the installation fails.
m_latz
I've edited dwgviewr.msi (created a transform) without any problems. Can you tell me what you want to change, that I can try on my site.
regards
Markus
bgraham247
For the last several years I've used Orca to modify the Property Tables to add a few extra paths to the install, highlighted below.  As example, I add a ";c:\acad\PlotStyles".  I have had some experience with transform files, but limited.  What software, if any do you use to create transform files and could you give me some tips on how you have created the transform file.  Thank you.
m_latz
Sorry for the delay.
You can use Orca to generate the transform file.
Here is an example how to edit a msi and save the modification as transform file.
https://autode.sk/3ayM77h
regards
Markus
