DWG TrueView 2016 Program Launch Error
cadman777
Advisor Advisor
Message 1 of 18
cadman777
Will someone please tell me what causes the error shown in the attached screen-shot, and how to fix it?
I just installed DWG Trueview 2016, and it won't open.
Thanx!
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Replies (17)
Message 2 of 18
cadman777
Here's the solution:
Adobe Acrobat 9 Extended: rename this file \Windows\System32\acapture64.dll (I renamed it to acapture64---.dll)
If you have other program start-up problems, here's a good site w/a good tool to help resolve them:
https://technet.microsoft.com/en-ca/sysinternals/bb963902.aspx
Autodesk has this documented on another site, but I forget where.
This is supposed to work w/AutoCAD no-starts too.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 3 of 18
Please clarify the solution described below with regard to the following points:
1. There is no file named acapture64.dll. I believe this is just a typo because on my machine (Windows 7 Pro, 64 bit), which does have Adobe Acrobat 9 Pro Extended installed, the file is named acaptuser64.dll. This latter file is in the directory C:\Windows\System32 as specified. Should the file named acaptuser64.dll be renamed?
2. If the file acaptuser64.dll is renamed, will it prevent Adobe Acrobat 9 Pro Extended from operating properly?
3. Should the system be rebooted after the rename operation?
Thanks.
Message 4 of 18
As an FYI, the same problem occurs with DWG TrueView 2015.
Message 5 of 18
ukdxb012
Hi @Anonymous
Take a look at the following knowledge article, there are some other suggestions of which you could try... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/The-app...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 6 of 18
The knowledge base article was helpful and it solved the problem with DWG TrueView 2016. Thank you Duncan.
Message 7 of 18
Thanks for the help.
I was having this error with DWG Trueview 2016.
Changing the registry key - as mentioned in the knowledge base article worked perfectly.
Thanks.
Incorrect Registry Key
A different program may incorrectly be switching a registry key from a 0 to a 1. Changing the value of the following registry key to 0 may help:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion \Windows\LoadAppInit_DLLs
Message 8 of 18
ukdxb012
@Anonymous No problem 🙂
Duncan Brannan
Twitter | LinkedIn
Message 9 of 18
I've tried to install DWGTrueView2016_ENU_64bit on my computer(I5,8GB Ram,4 GB Display card)
Got the following eror. Kindky your hellp needed.
Message 10 of 18
pendean
Community Legend
Community Legend
You need to post the installation log file: a link to it was on the pop-up you took a screenshot of.
Message 11 of 18
Thanks Dean.
Attached  the log file.
Message 12 of 18
Hi Dean,
Have you managed to look at the log?
Many thanks in advance,
Hadar
Message 13 of 18
pendean
Community Legend
Community Legend
The log file reports these most common issues:
Installation aborted, Result=1603
DirectX Runtime Failed Failure is ignored, Result=1619
A Google Search should get you links to tips to try, they are quite numerous to re-write here.
Message 14 of 18
Nope. Try the solutions mention(re install directx,using other installation folder etc')
I'm kind of desperate. The issue is that in my laptop(old one but working good) the install goes smooth and it's up and running.
and in my Desktop which is my main work place i can't finish the installation.
Any opter ideas will be great 🙂
Many thanks,
Hadar
Message 15 of 18
pendean
Community Legend
Community Legend
Restart Windows and ensure you are logged in as full admin in Windows.
Turn off all background apps, turn off your anti-virus
Open your Windows log in TEMP folder and empty it.
Leave that folder open in Windows Explorer.
Now try installing your software.
Message 16 of 18
Hi Dean,
Done all this step by step but nope 😞 .
Here's the log agian,i'll be graitful for any help(even remote if possible) as i'm kind of desperate .
Many thanks,
Hadar
Message 17 of 18
pendean
Community Legend
Community Legend
Post 13 above, you've got to try to dig a little deeper, you're still getting the same errors.
Message 18 of 18
hi,
i trying to install DWG Trueview 2018 version.
it showing some error
can you fixed it ?
i am using win 10 64bits
