any suggestion on what to use for Construction sequence animation? Navisworks is not too presentable.
Navisworks. Which you might combine with Microsoft Projects (possible other planning software).
Louis
Please mention Revit version, especially when uploading Revit files.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Hi @ar_micahbaleciado
Thanks a lot for posting your question to the forums! Have the solutions suggested by @barthbradley @L.Maas @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
This is what we are currently using but navisworks' rendering is not 'too presentable'
