Error report error report
Message 1 of 15
In case AutoCAD tries to send an error report after a crash, instead of going to the autodesk site and getting a message like "install patch" or "we'll work on it", we now get dumped into google with no results for trying to find "https://errorreport.autodesk.com/progress.jsp?xid=-%14%1A%08%11%04%14%0E%7CrE%40GI%0E%00%00%2C%16O%5..." (for example).
This is using Edge, AutoCAD 2018, win 10...
Replies (14)
Message 2 of 15
RobDraw
... and?
Is there a question here?
Rob
Message 3 of 15
pendean
Community Legend
Community Legend
Edge?
Message 4 of 15
Edge is Microsoft's replacement  for Windows Explorer in Windows 10
Message 5 of 15
RobDraw
That would be Internet Explorer.
File Explorer is the replacement for Windows Explorer.
Rob
Message 6 of 15
Oops, Internet Explorer
Message 7 of 15
It's a bug report for the bug reporting... if any question: how do I make autocad not do this?
"Your search - https://errorreport.autodesk.com/progress.jsp?xid=-%14%1A%08%11%04%14%0E ... - did not match any documents. "
Message 8 of 15
RobDraw
Don't know if this will help, but have you tried changing your default browser?
Rob
Message 9 of 15
Good idea! Though my default browser in IE and autocad insists on using Edge... It's at least worth looking into.
Message 10 of 15
Message 11 of 15
I'm having this same issue.  I would prefer to not have to come up with a workaround (e.g. changing my default browser). Has anyone received word as to whether the error reports are going through, or how to keep them from being entered as a Google search, instead of a web address?
I've had WAY TOO MANY crashes in Revit 2019, and based on the lack of responses (exactly 0) from Autodesk, I assume they are not receiving the error reports.  Or, maybe they just ignore them because the program becomes less compatible with Windows 10 after every update.  Case and point: My Revit was crashing at the splash screen during every startup.  After trying every solution suggested on the internet, I finally figured out that I needed to manually change the licensing - by editing a .data file located here: ProgramData\Autodesk\CLM\LGS\829K1_2019.0.0.F... (I couldn't believe I had not thought of that sooner!!!).
Message 12 of 15
RobDraw
Really? Then a lot of us are in big trouble.
Rob
Message 13 of 15
pendean
Community Legend
Community Legend
CERs are only responded to in real time if the solution is known: otherwise you will never hear anything from anyone at Autodesk, CER is simply a crash-reporting tool for them.
Sounds like your system setup may need a review as well: an office full of REVIT2019 users with server component over here in WIn10Pros/WinServer2012 and we are not seeing crashes.
Message 14 of 15
nmarshall
I have a similar issue.  I am currently getting frequent crashes on a project in 2018 with a display error - current 2018 version, current graphics driver, acceleration turned off as recommended in posts.
Why can't an error report be sent when Edge is your browser?
Message 15 of 15
nmarshall
I have the same issue.
Edge is the Microsoft default browser.  Autodesk should be able to work with it.
Internet Explorer is out of date and will not open many web pages, so it is not practical to set as default program. Google Chrome is a hog so not good to run with Revit.
Autodesk please fix the bug in your bug reporting to use Edge.
Nicky
