adding column frames to multitext
I have created a multitext with dynamic columns. However, I would like to enclose each column with a box. How can I do that with out individually drawing a box around each column?
What type of Autocad Version you running ?
autocad 2011
Are you making the columns with table style?
No. I used text formatting to get the dynamic columns.
I see...no Autocad 2011 dosent have that type of option. I work with 2012 LT i don't have it either. You will have to do it manual.
A rectangle around the text.
