TPF Ingeniería | Efficiency Underground: Málaga Metro's BIM and IFC 4x3 Integration
lim.wendy
Alumni Alumni
Message 1 of 11
lim.wendy
The extension of line 2 in the Málaga Metro project was done using the Building Information Modeling (BIM) methodology, considering the complexities of construction in an established urban area. Significant efforts were invested in various tasks, including the creation of a 3D model for a cut and cover tunnel with slurry walls, coordination of different disciplines using Navisworks, and conducting 5D budget analysis.
 Those attending the event will witness a real-life example of a civil infrastructure project that employed Autodesk software. Numerous challenges were encountered during the project's design phase. Specifically, the utilization of specialized tools in Civil 3D to calculate lofted volumes and the adoption of parametric modeling tools for water supply networks, sanitation, and electricity were crucial in developing the models. Furthermore, noteworthy advancements were made in the IFC exportation processes by Autodesk for the IFC 4X3 version. The presentation will showcase multiple models to illustrate these concepts.
Speaker:
78179a1d287b41918c54d52ebde86807!_!aa64102458eedc6e839e1276afc89b67
Rosa Ureña Bolaños
BIM Manager
TPF Ingeniería
Audience / Project Role:
Engineering Services Provider
Autodesk Rail Software Solutions used:
Company:
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (10)
Message 2 of 11
lim.wendy
You can find the presentation slide that was uploaded to this post.
Wendy Lim
Rails Summit
Message 3 of 11
lim.wendy
Hi @rosa.urenaJTRL3
Thank you for speaking at Rail Summit 2023!
If you have any more thoughts or if you'd like to elaborate further on what you presented or provide additional resources, please feel free to reply to this post.
Wendy Lim
Rails Summit
Message 4 of 11
kevin_schmidt
Hey, thanks for the presentation. I see you worked in Civil 3D, may I ask: Are the sleepers a reference of one object or each a unique defined geometry? If they are placed as references, how did you manage to do that in C3D?
Message 5 of 11
lim.wendy
Hi there, @rosa.urenaJTRL3, thank you again for your informative presentation! It's great to see your expertise in Civil 3D.
@kevin_schmidt, that's a fantastic question regarding the sleepers in Civil 3D. I'm sure @rosa.urenaJTRL3 can provide some insights into this.
Rosa, the user is interested in whether the sleepers in your presentation are treated as references or unique defined geometries in Civil 3D. Additionally, if they are placed as references, they are curious about the method you used to achieve this in Civil 3D.
Your response would be greatly appreciated to shed some light on this aspect of your presentation. Thanks in advance!
Wendy Lim
Rails Summit
Message 6 of 11
kevin_schmidt
havent heard back yet
Message 7 of 11
wouter.bulens72EDZ
Hi @kevin_schmidt,
Sadly, I do not know exactly how @rosa.urenaJTRL3 did this on the project. But from what i can see on the slides, I would expect that this is automated 3D Block placement. The contained geometry is supported by the IFC 4.3 exporter so that would assure their workflow. This automated placing can be achieved through the use of Dynamo in Civil 3D. using the alignment, profile geometry and the cant values exact placement can be calculated. If needed, we can certainly help u look further in the right direction.
Message 8 of 11
kevin_schmidt
so the geometry in the ifc4x3 is only defined once and then just referenced for the other positions?
Message 9 of 11
wouter.bulens72EDZ
Hi @kevin_schmidt,
While I am not the biggest authority on IFC, if i remember correctly IFC does not have an instancing definition. So, the geometry of every object is included. Making it a complete, but heavy exchange format. If you define the right meta data on the objects, you might be able to identify and process instances differently. But other IFC viewer will not process the files in the same way. (@heidi_castellanos_leyra, can you confirm or add?)
Message 10 of 11
kevin_schmidt
Thats one of the big changes that IFC4x3 is supposed to bring. References along an alignment should be possible as far as I know. I just don't know how to do that in C3D, thats why I asked my initial question.
Message 11 of 11
Hi @kevin_schmidt@wouter.bulens72EDZ ,
Indeed, IFC will exchange the geometry of each sleeper or any other rail object, with the metadata included, if you map it to the good class 🙂
Its each object geometry that's being exchanged, you can add the technical reference for the sleepers in the ¨Pset_TrackElementTypeSleeper" if you need to make reference to a national standard, reference geometry.
Hope it helps
