Autodesk Rail Community Knowledge Center
Share and learn how-to tips, workflows, and general knowledge articles about rail topics.
A better way to convert data from the as-built OCS layouts into a neat and tidy table
A while ago, I was working on a project where the client gave us some .dwg files of the catenary as-built layouts. The pole parameters were just text boxes arranged in a certain order. There were like 50 sheets and 40 poles per sheet. That's a lot of text boxes! 😱
I don't know about you, but I hate typing tables manually. It's so tedious and error-prone. 😩
So, I decided to write a little script in Dynamo that does all the work for me. It collects and organizes the data into a table format (rows for poles, columns for OCS parameters) and creates .csv files for each sheet. Then, I can use PowerQuery to merge all the files into one big Excel table (that's what I did) or use some other tool to aggregate them.
This way, I can easily work with the as-built data: analyze it, check it, calculate it, count it. You name it, I can do it. 💯
Sounds awesome, right? Well, it is! And I'm feeling generous today, so I'm going to share my #script with you. You're welcome. 😊
Below, you can watch a short video of how the script works, and also download the files from this link. Use it, improve it, save your time. 😉
