Message 1 of 11
11:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been getting questions from co-workers about what assumptions are being used when creating scenarios in Insight 360 from Revit models. For example:
- Are the energy settings in Revit carried over to Insight 360? For example, if I changed the building type from Office to Parking Structure, would the EUI be adjusted accordingly?
- When the model comes from Revit into Insight 360, how is the ASHRAE 90.1 and Architecture 2030 benchmarks determined? Does it take the building use/type into account when comparing against those benchmarks?
- How does the operating schedule of the model analyzed? Is at 12/5 schedule mean that the other 12 hours a day the HVAC is turned off completely or does it maintain a minimum comfort threshold?
- When you adjust he WWR, does it adjust the % difference against the imported glazing % (how it looks in the 3D Insight model view) or does it reset the glazing %?
- Is there a document somewhere the explains more about the detailed assumptions used for the various Insight widgets? These would be useful when trying to understand what exactly is being factored into the calculations.
Justin
