Hi Krishnan,
Thanks for your reply and great to hear that you are going to incorporate features from Project Solon into Insight 360. I am interested in using the charts as a visual tool in ESD reports and for education purposes, with the aim to respond to local climate and show the greatest resource savings potential. Since there are 3 tools with similar functions (Results & Compare, GBS, Insight 360), below is an outline of the functions I am interested in each of these:
Results & Compare / Project Solon
- All default charts in Results & Compare are useful
- It would also be great to custom design charts as per widget and dashboard creation in GBS/Project Solon. This would enable individually chosen graphics and parameter combination of climate data, time, resource usage, cost etc.
- Carbon neutral potential
Additional desirable functions from previous Autodesk software versions:
- Potential energy savings chart – compares multiple impacts in one graph
- Wind roses – the graphics are great, however it would be useful to customize the time as previously possible in Ecotect to show the impact on natural ventilation potential, e.g. cooling morning or afternoon breezes in hot climates (currently only wind speed & frequency available). On a related note, summer and winter are mixed up in Australia.
I would like to use the charts in my current reports for education buildings. As I understand the original Revit 2016 version would enable access to Project Solon, where can I download it? Results & Compare in the current v2017 (not 2017.1.1 upgrade) shows error messages before generating results (Cannot find path / problem with energy analysis service, cannot finish previously started runs). Is it possible to eliminate these?
GBS
- Annual electricity end use
- Water usage
- Carbon footprint / carbon neutral potential
- Natural ventilation potential
- Wind generation potential
Insight 360
- Energy measures are covered well, however GBS goes beyond energy
- Architecture 2030 Challenge link is great if international data available, waiting on extension to residential building type
- Solar Analysis – works in Revit but not in Insight 360 (error message: no selected panel types meet payback limits, see below). This has been the case in all my projects, is there a way to fix it?
Thanks for your interest in my feedback, I hope this is useful and would appreciate if you could shed some light on the questions above.
Chris Renger
