Construction Thermal Properties
Hi
How can i make sure that my energy analytical model pulls the thermal properties from construction materials i used for my model?
Note: i am using revit 2019 for energy simulation
Hi @Anonymous,
In the Insight Energy Settings > Advanced > Material Thermal Properties make sure to select "Detailed Elements." Otherwise the Insight default constructions and thermal properties will be used in the analysis.
Please click the "Accept as Solution" button if this solves your issue or answers your question so that others may also benefit from the information.
Felipeespv
Hi @Felipeespv ,
Did you have an additional question or comment? Your previous post was blank.
