Viewing links within file
Is it possible to view links within a single file within Autodesk drive's 3D view mode? I seemingly am able to view individual pieces of my model however when going to the file that contains said pieces as links it displays nothing. I also noticed this image on said master file.
Are there any plans to intergrate the funcionality to be able to view links within a project? I know from previous experiences that a360 did not support said functionality. If it already does how do I display my loaded rvt links?
helpdesk
Hi there,
You must make sure that the links are also transferred to Autodesk Drive.
If you want to view links you should do the following:
1) Put the file you want to link on Autodesk Drive
2) Link in the files, locate them on Autodesk Drive.
3) Save and close
I suggest you look around also in the BIM 360 Team forum for help on this because the product is using the same technology.
