I apologize for my English!
I'm logging into Autodesk Drive, but it won't let me add files, it says I have to have an Autodesk Drive right.
But I am logging in with my user from my company in which we have token licenses, why could it be that it is not letting me use the platform?
Thanks: you appear to be logged in with the incorrect account, or your Autodesk Accounts Manager has (if that's also you, you might have unintentionally) removed access for you to use Drive.
If you believe all of that is not applicable, then you will open a support case with Autodesk (subscription also required, so if you can't with your log-in, then you're likely not) to seek out Autodesk Support's help with access:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
