Inventor Professional 2022.1 update can't find the file "Inventor.msi"
MikeMullins
MikeMullins
I have tried several time to install the Inventor Professional 2022.1 update and it has failed every time.  Is anyone else experiencing this problem?
Replies (18)
petter
Same problem...scanned my computer for it but is nowhere to be found.
I guess there will be a new release of the update soon that includes the file.
MikeMullins
Thanks for the reply.  I posted the issue because I was having trouble installing the .1 update.  My solution ending up being the total uninstall and reinstall of Inventor.  Which was as I expected, was a nightmare.  It seems to have resolved the problem as I have not had any issues with the latest updates.
Mike Mullins
g.masina
Community Visitor
Community Visitor
The same thing happens to me, but I don't want to reinstall inventor! Nothing from autodesk for this issue?
MikeMullins
Nothing from Autodesk to date.
rmonti.ut
I have the same problem with Inventor Pro 2022.2
MikeMullins
You have my sympathy.  My solution was to un-install and re-install Inventor.  As far as a fix from Autodesk, nothing but radio silence.  Wish someone had a better solution.
Mike
pendean
Community Legend
Community Legend
>>>... fix from Autodesk, nothing but radio silence...<<<
@Anonymous @rmonti.ut Autodesk Support is reached this correct way only if you have a paid subscription https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~:text=To%20contact%20support%3A,to%20access%20help%20and%20support.
MikeMullins
Thanks for the reply.  I do have a paid subscription thank you.  And if Autodesk has a fix, why did no one reply to my original post back in July?
Regards
Mike Mullins
pendean
Community Legend
Community Legend
@Anonymous These forums are peer supported: end users helping other end users. Contributors only reply when they have an answer, apparently no one did in your case.
You also opted to post in a forum for a sloppy nanny-app that Autodesk bundles with their software that is hideously supported by Autodesk, so if someone from Autodesk does float in here they could only be equipped to help you fix the nanny app, not your more detailed issue.
For all installation and licensing issues, the better forum to seek help in is this one https://forums.autodesk.com/t5/installation-licensing/bd-p/24
Now you know.
MikeMullins
I did search the Autodesk site for a solution but found nothing at the time.  I was hoping for suggestions from a peer supported forum.  I have found peer support can be pretty good sometimes.
I'm sorry to hear you feel that Inventor Pro is a "sloppy nanny-app".  In your opinion, what is a better CAD platform to use?  I have used several CAD apps, (CATIA, RHINO, PRO E, Sketch Up) and find Inventor to be the most convenient for getting the job done.
pendean
Community Legend
Community Legend
No, you overread it, I was not talking about Inventor/Pro, but the topic of this forum aka the AUTODESK DESKTOP APP (ADA), you posted in the wrong forum for your Inventor Installation issues, you posted in the forum about problems using the Autodesk-Ignored app ADA.
These forums are sorted by topic, this was not a good spot for your exact post topic/issue. That's why it got ignored for so long.
HTH
K.TRYFONIDIS
Hello all,
A workarround you can do and actually works is as follows:
1) Go to all products and services.
2) Find inventor and click download
3) * Important * download all 3 files, make sure you allow pop up windows.
4) Create a folder and name it as you like ( i named it "inventor") at download folder.
5) open 001 file and extract to the folder you created.
6) Inside the extracted folder type to top right corner at search bar *.msi
This will list all .msi files.
7) Click and install the missing .msi file.
In my case it was InventorLP.msi
8 ) 😎 Run update patch again.
Jan-EootB
This is the solution. Thank you.
The problem is still active on update 2022.3.2
A shame that "some user" must provide this information.
jiriDVKHM
Unfortunately only installer has been downloaded, not 3 files...
K.TRYFONIDIS
Hi, Check for blocked popups on your browser.
jiriDVKHM
I've tried through two browsers... 😞
K.TRYFONIDIS
Ok Ok i believe you. I came across ( again ) with the same issue.
Luckily, we managed to get through the problem with the help of Autodesk support.
All you have to do is find the inventor.msi file again but in little different steps as bellow:
1)  Go products and services.
2) Download installer for inventor
3) double click to install and wait , it just creates installer, no install happening yet.
4) installer finished creation
5) open folder
Inside there it is at the path
6) Run Inventor.msi and wait about 5 minutes, it runs in background. You might need to restart pc after this.
7) Run update afterwards again
😎 enjoy.
kostremEEC7J
The last post was how I was able to successfully update Inventor 2022. I've been missing updates since 2022.1 and finally battled through the missing file.
Thanks for the posts all.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
