Revit 2023: Revit Walls - An Alternative Approach to Design and Creation Series 4 of 6
Method 4 – Curtain Walls with Custom Profiles and Wall Sweeps
  • This method is meant to use custom profiles, custom sweeps and nested families within custom profiles to create “stick framing,” and custom structures in a repeated fashion.  The key thing to remember in this method is that you are inserting a custom family inside the mullion profile family as well as inserting horizontal wall sweeps (control the start/end points manually) to make unique designs.
Pro Tip:  Use manufacturer specific mullion profiles if you want your curtain walls to have proper extrusions based upon that manufacturer content.
6 Comments
