Autodesk Community Tips - AutoCAD Products
Autodesk Community Tips are bite-sized fixes, shortcuts, advice, and how-to tips shared by Community members.
Use shift key in AutoCAD for increased productivity - Part 2 - Object Snap > From
Contributed by:
Did you know you can establish a temporary reference point as a base point for offsetting subsequent points?
The From command modifier establishes a temporary reference point as a base point for offsetting subsequent points and usually is used in combination with object snaps.
It enables users to choose a temporary reference point than the selected base point origin; This can be achieved by choosing From from the snap override menu.
At a prompt for a point, enter From. Alternately, press Shift and right-click to display the object snap menu, and then choose FROM.
If you want to offset from a location on an existing object, specify a reference point.
Enter a relative coordinate such as @Anonymous,50 -  @ x, y
Check out my other helpful tips in the series.
handjonathan_0-1678440882525.png Insider Community Tips_Using Shift Part 2.png
