Autodesk Community Tips are bite-sized fixes, shortcuts, advice, and how-to tips shared by Community members.
The SHIFT key is a significant tool that can assist users in enhancing their productivity in AutoCAD. Here, we'll look at some quick hints for using AutoCAD's SHIFT key to speed up your drafting process.
HOLDING SHIFT for Temporary Ortho MODE
Ortho mode is a helpful feature in AutoCAD that constrains movement to the horizontal and vertical axes.
To activate ortho mode, press the F8 key on your keyboard. However, holding down the SHIFT key will lock ortho mode on, allowing you to move objects in a straight line. To unlock ortho mode, simply stop pressing the SHIFT key again.
Check out my other helpful tips in the series.
