Autodesk Community Tips - AutoCAD Products
Autodesk Community Tips are bite-sized fixes, shortcuts, advice, and how-to tips shared by Community members.
Quickly Change Block Attribute like it was DTEXT
Contributed by:
You can quickly change an Attribute Value in a block by holding down the ctrl key while double clicking on the Text Attribute. This allows you to change the attribute without using the Enhanced Attribute Editor.
In the video below you can see using each method to change a block attribute. If a you only need to make a quick simple change to an attribute hold down Ctrl and double click the attribute. This will allow you to edit the attribute value as though it was DTEXT.
Comments
Great tip @TheCADnoob i didn't know you could do that 😁
Nice tip !  I did not know that either...
Very nice
