Autodesk Community Tips - AutoCAD Products
Autodesk Community Tips are bite-sized fixes, shortcuts, advice, and how-to tips shared by Community members.
Lengthen Command: Measure Twice, Lengthen Once
Contributed by:
The Lengthen command in AutoCAD can modify various types of objects, including lines, arcs, polylines, open splines (limited options), and elliptical arcs. It allows you to adjust the lengths of these objects, either by a specific value or by a calculated distance, offering flexibility and control over the dimensions of your designs.
(view in My Videos)
This tool can be found on the Home Tab - Modify Panel - LENGTHEN LENGTHEN.png
Alternatively, you can type this command into your Keyboard, LENGTHEN or LEN.
This command is all Command Line driven, so make sure you have it turned on (CTRL+9 / Commandline) for a better experience.
After activation, you will be prompted to choose an object to begin, you can select more than one object. Your options include Delta, Percent, Total, and Dynamic.
DELTA
Shorten or Lengthen a selected object by a specific value. When you provide a positive value, the object will be extended, whereas a negative value will trim it.
Percent
Allows you to modify the length of objects by a specified percentage. Instead of inputting a specific value or distance, you can enter a percentage value to adjust the length proportionally.
Below 100 will trim your object, where as over 100 will extend it.
Total
Allows you to set the length of a selected object by specifying the total absolute length from a fixed endpoint. If your object is 27.42 and you need 27.5, Total will get you there quickly.
Dynamic
This enables Dynamic Dragging mode. This mode allows you to change the length of a selected object by dragging one of its endpoints while keeping the other endpoint fixed.
(view in My Videos)
Let your imagination stretch as you play with lengths, experiment with curves, and bring your designs to life. Get ready to have a blast while mastering the art of precision in your CAD creations. Go ahead, give it a try, and let the fun begin!
AutoCAD Support and Learning - Links
LENGTHEN (Command)
To Lengthen an Object
Comments
A shout out to my friend @DragonLady9910 - Jenn Kennedy for reminding me about this command.
Great tip @kristina.youngblut
It is ridiculous how handy this tool is.  I got out of habit with it when I was doing parametric design as I was controlling with parameters and formulas. Now that I am doing more 2D design, it has become very handy.
I do use the LEN command often, expecially when  i discovered it was an option with using GRIPS.  i click in the grip, hover for a second and the option pops up.  its really useful when i have a line on an angle.  thanks!
@kristina.youngblut Thanks for sharing this one Kristina!!  It is truly one of my favorite commands, and definitely one that everyone should know. It's handy in so many scenarios while designing and drafting.
Thanks @kristina.youngblut! I knew about the LEN command, but have only used total length. Good to know it is a versatile command.
Saludos @kristina.youngblut
Muchas gracias por tomarte el tiempo para hacernos recordarnos este comando. Lo uso casi siempre para extender (alargar) una linea conservando su ángulo de inclinación. Aunque hay otras formas de hacerlo (referencia a objetos-extension) Pero con LENGTHEN->DINAMIC, puedo asegurarme de conservar el Angulo de inclinación para la extensión.
No se porque no es posible alargar una polilinea. Seguro que puedo hacerlo con una rutina LISP, pero no encontré la forma de hacerlo directamente. 😊
@calderg1000
Thank you for your kind words. I love tiny commands like this that make our lives so much easier. Polylines and Splines, have so much more opportunity!
@kristina.youngblut Thanks for sharing this command. I had forgotten about this one. I use the grips a lot, I will remember to use LEN again. I started a Tech Tuesday at work and this will be one of the commands I share with the Team. - Jeff.Beaver
@Jeff_Beaver I love this command! So glad it can add to your support of others. The whole purpose of these tips is to make every day a little bit easier and utilize the software to its full potential.
