Autodesk Community Tips - AutoCAD Products
Autodesk Community Tips are bite-sized fixes, shortcuts, advice, and how-to tips shared by Community members.
CTRL is your friend!
Contributed by:
A quick little tip for those who don't know:
When working with multiple layouts it can be quite tedious to right click > move or copy > create a copy...
if you use this method you'll be happy to know that holding CTRL (Control) on your current layout and dragging it left/right will create a copy for you quick and easy!
CTRL has many other applications;
For example when editing a block with multiple attributes, holding CTRL and double clicking will allow you to edit your attribute in place without the annoying pop-up screen!
Comments
Thanks @Brock_Olly such a simple thing to do and makes you tons more productive
Great tips! Especially about the attributes.
oh man, the ctrl double click is slick. I have a editing tool that works on text, mtext, dimensions, atts under one key-in "D", but for those without that, much better than DDATTE dialog!
Another control key trick for attributes - hold down CTRL and left click an attribute and you can adjust its properties independently of the rest of the block it's in. You can build a selection set of just attributes and move them around as a group. I do this in AutoCAD Electrical quite a bit because sometimes the attributes in the symbol get in the way of other things.
Making Multiple Copies With Grips using the Ctrl key remembers displacement for Move or Rotate.
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-BCD1FCDB-67A2-45B0-9679-063505733210
Ctrl+Home Start Page
Ctrl+Pg↑, +Pg↓ to switch layouts left/right ⇆Layouts same as tabs on a browser.
Ctrl+Shift+A Select Similar
Ctrl+C Copy with Base Pt
Ctrl+L Sel Previous or set highlighted Mtext to Lower Case
Ctrl+U to set highlighted Mtext to Upper Case
Ctrl+V Paste as Block
Ctrl+F2 Text Window▭
Ctrl+0 Clean screen
Ctrl+1 Properties
Ctrl+Shift+P QuickProp
Ctrl+2 Design Center
Ctrl+3 Tool Palettes
Ctrl+4 Sheet Set Manager
Ctrl+9 Command Line▭
Ctrl+H Toggle Groups Off/On
Ctrl+I Coords Off/On/Relative
Ctrl+R Cycle Viewports
Edits
Ctrl+C Copyclip
Ctrl+V Pasteclip
Ctrl+X Cutclip
Ctrl+Shift+C Copyclip with Base Pt / copybase
Ctrl+Shift+V Pasteclip as Block
Ctrl+Shift+X Cutclip with Base Pt / cutbase
These are all so awesome!
Shift+right-click selection list of osnap options (endpoint, etc)
