公告
Autodesk 社区论坛界面焕然一新。请在社区公告板块了解更多变化。
CAD2023安装失败错误1603,提示找不到AcPerfMon.msi
792687953
792687953
在此之前安装过2019版并且卸载,重新安装2023版时遇到了此问题。弹出对话框如图,提示安装Feedback tool出错?已经删除了所有注册表项,仍然无法解决。QQ截图20220711194833.jpg
0 个赞
回复
已接受的解答 (1)
6,806 次查看
10 条回复
回复 (10)
Michiel.Valcke
Have you tried changing the 'Use source' URL to the location of your new AutoCAD 2023 installation?
For a standard installation (Windows) that should be:
C:\Program Files\Autodesk\AutoCAD 2023\acad.exe
0 个赞
792687953
This happens during the installation process, about 43% of the progress.
0 个赞
792687953
When I click OK,therQQ截图20220711201359.jpge will be prompts like picture.
0 个赞
792687953
hello?
0 个赞
WeTanks
你好。
也许是你的w10的问题。
再建立一个新的账户,重新安装试试?
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Michiel.Valcke
I believe you can manually fix the AcPerfMon.msi problem
https://www.exefiles.com/en/msi/acperfmon-msi/
But I would first check how you install AutoCAD. Are you using a deployment file? If so the problem could originate with the deployment file. Go to manage.autodesk.com and download the installation files directly from there (browser download) or do an installation with the autodesk desktop app.
As @WeTanks said, also check your user profile before installing: make sure you have administrator rights, shut down UAC
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-t...
792687953
我使用的是windows11系统,新建了账户还是不可以
0 个赞
Michiel.Valcke
Do you have administrator rights on your computer / account?
0 个赞
792687953
yes
0 个赞
Yong.Jing
Autodesk Support
Autodesk Support
已接受的解答
请参考此链接的解决方法:
原因
在安装新的 Autodesk AutoCAD 性能反馈工具 1.3.12 之前,AutoCAD 2023 安装程序无法卸载 Autodesk AutoCAD 性能反馈工具 1.3.0。
解决方案:
要完成 AutoCAD 2023 安装而不出现其他问题:
如果您仍有 AutoCAD 2019 安装文件夹,请浏览 Autodesk AutoCAD 性能反馈工具 1.3.0 MSI (AcPerfMon.msi)
1, 在打开的窗口消息中单击“浏览...”。
2, 在文件夹“/Tools/PerformanceTool/”(默认为“C:/Autodesk/AutoCAD_2019_English_Win_64bit_dlm/Tools/PerformanceTool”)中搜索 2019 AutoCAD 安装程序随附的 AcPerfMon.msi 文件。
删除 Autodesk AutoCAD 性能反馈工具 1.3.0
1,下载Microsoft 疑难解答(也称为 Microsoft Fix-It)。
2, 运行 Microsoft Fix-It 以远程 Autodesk AutoCAD 性能反馈工具 1.3.0。
3, 重新运行 AutoCAD 2023 安装。
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
