请参考Autodesk Privacy Statement
若要关闭Data Privacy的窗口, 请参考Autodesk隐私声明在被接受后仍反复出现
解决此问题:
- 退出所有 Autodesk 程序。
- 导航到以下文件夹:C:\Users\\AppData\Local\Autodesk\Adlm
- 将AdlmUserSettings.xml文件重命名为AdlmUserSettings.xml.old。
注意:如果重命名文件未阻止隐私声明窗口显示,请检查Autodesk文件夹的权限(单击鼠标右键>“属性”>“安全性”)。确保为当前用户和组帐户提供“完全控制”。
As a workaround, it may be possible to edit the AdlmUserSettings.xml file and enter the data to signify that the privacy statement was accepted. Open AdlmUserSettings.xml in Notepad and make sure the following is present:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<AdlmSettings>
<Section Name="PrivacyPolicyConsent">
<Data Key="001F1:2014.0.0.F">1</Data>
</Section>
</AdlmSettings>
Note: The example above is for AutoCAD 2014 as indicated by the Data Key field: 001F1.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
