merhabalar. yaklaşık bir aydır autocad 2017 öğrenci sürümünü defalarca denememe rağmen kuramadım ve her zaman aynı sorunla karşılaştım, farklı tarihlerde, sitelerde ve burada çözüm olarak sunulan şeyleri uyguladım fakat bi türlü istediğim sonuca ulaşamadım. material library kısmında microsoft visual c++ 2015 redistributable veya benzer sorunla karşılaşıyorum. umarım yardımcı olabilirsiniz teşekkür ediyorum şimdiden
2017/3/8:14:28:47 user LENOVO-PC === Setup started on LENOVO-PC by user ===
2017/3/8:14:28:47 user LENOVO-PC Path_Length: 162
2017/3/8:14:28:47 user LENOVO-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_Trial_en-us
2017/3/8:14:28:47 user LENOVO-PC Launch
2017/3/8:14:28:47 user LENOVO-PC CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_Trial_en-us_Se..."
2017/3/8:14:28:47 user LENOVO-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIBD5B.tmp
2017/3/8:14:28:53 user LENOVO-PC === Setup ended ===
2017/3/8:14:28:50 user LENOVO-PC === Setup started on LENOVO-PC by user ===
2017/3/8:14:28:50 user LENOVO-PC Path_Length: 162
2017/3/8:14:28:50 user LENOVO-PC Current Directory C:\Users\user\AppData\Local\Temp\_AIBD5B.tmp
2017/3/8:14:28:50 user LENOVO-PC Launch
2017/3/8:14:28:51 user LENOVO-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUPMARK...
2017/3/8:14:28:52 user LENOVO-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/SETUP_x64...
2017/3/8:14:28:52 user LENOVO-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AIBD5B.tmp\Setup\AcSetup.dll
2017/3/8:14:28:52 user LENOVO-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/8:14:28:53 user LENOVO-PC PageOpen LaunchDialog
2017/3/8:14:29:17 user LENOVO-PC PageOpen LicenseDialog
2017/3/8:14:29:17 user LENOVO-PC PageOpen ProductInfoDialog
2017/3/8:14:29:17 user LENOVO-PC PageOpen ProductSelectionDialog2
2017/3/8:14:30:20 user LENOVO-PC PageOpen FullProgressDialog
2017/3/8:14:30:23 user LENOVO-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/3/8:14:30:23 user LENOVO-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/STARTMARK...
2017/3/8:14:30:24 user LENOVO-PC Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/3/8:14:30:24 user LENOVO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/3/8:14:30:44 user LENOVO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/3/8:14:30:44 user LENOVO-PC Download Skipped VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/3/8:14:30:45 user LENOVO-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/3/8:14:31:05 user LENOVO-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/3/8:14:31:06 user LENOVO-PC Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/UCRT_x86....
2017/3/8:14:31:06 user LENOVO-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/8:14:31:06 user LENOVO-PC Install Universal C Runtime (KB3118401) Succeeded
2017/3/8:14:31:06 user LENOVO-PC Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/3/8:14:31:06 user LENOVO-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\user\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/8:14:31:18 user LENOVO-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/3/8:14:31:18 user LENOVO-PC Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/VCREDIST2...
2017/3/8:14:31:18 user LENOVO-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\user\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/8:14:31:19 user LENOVO-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/3/8:14:31:19 user LENOVO-PC Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/DIRECTX.t...
2017/3/8:14:31:19 user LENOVO-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/8:14:31:34 user LENOVO-PC Install DirectX Runtime Succeeded
2017/3/8:14:31:36 user LENOVO-PC Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/3/8:14:40:01 user LENOVO-PC Download Error CM <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/3/8:14:40:07 user LENOVO-PC Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{12D55A88-A908-4C16-A40A-90D9D60A01F4}/CM.tar.lz...
2017/3/8:14:40:07 user LENOVO-PC Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/8:14:40:08 user LENOVO-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/8:14:40:08 user LENOVO-PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/3/8:14:40:08 user LENOVO-PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/3/8:14:40:10 user LENOVO-PC PageOpen InstallCompleteDialog
2017/3/8:14:50:07 user LENOVO-PC === Setup ended ===
2017/3/8:15:17:34 user LENOVO-PC === Setup started on LENOVO-PC by user ===
2017/3/8:15:17:34 user LENOVO-PC Path_Length: 162
2017/3/8:15:17:34 user LENOVO-PC Current Directory C:\Autodesk\AutoCAD_2017_English_Win_32_64bit_wi_en-us
2017/3/8:15:17:34 user LENOVO-PC Launch
2017/3/8:15:17:34 user LENOVO-PC CommandLine /akamai /sid a1b3A00000AMtUZQA1 /skipEULA /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_English_Win_32_64bit_wi_en-us_S..."
2017/3/8:15:17:34 user LENOVO-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI686A.tmp
2017/3/8:15:25:50 user LENOVO-PC === Setup ended ===
2017/3/8:15:17:37 user LENOVO-PC === Setup started on LENOVO-PC by user ===
2017/3/8:15:17:37 user LENOVO-PC Path_Length: 162
2017/3/8:15:17:37 user LENOVO-PC Current Directory C:\Users\user\AppData\Local\Temp\_AI686A.tmp
2017/3/8:15:17:37 user LENOVO-PC Launch
2017/3/8:15:17:39 user LENOVO-PC Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/3/8:15:17:40 user LENOVO-PC Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/3/8:15:17:40 user LENOVO-PC Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/3/8:15:25:48 user LENOVO-PC Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/SETUP...
2017/3/8:15:25:49 user LENOVO-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI686A.tmp\Setup\AcSetup.dll
2017/3/8:15:25:49 user LENOVO-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/8:15:25:50 user LENOVO-PC PageOpen LaunchDialog
2017/3/8:15:27:37 user LENOVO-PC PageOpen LicenseDialog
2017/3/8:15:27:37 user LENOVO-PC PageOpen ProductInfoDialog
2017/3/8:15:27:37 user LENOVO-PC PageOpen ProductSelectionDialog2
2017/3/8:15:28:03 user LENOVO-PC PageOpen FullProgressDialog
2017/3/8:15:28:05 user LENOVO-PC Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/3/8:15:28:05 user LENOVO-PC Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/START...
2017/3/8:15:28:06 user LENOVO-PC Download Play UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/3/8:15:28:20 user LENOVO-PC Download Complete UCRT http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/UCRT_...
2017/3/8:15:28:20 user LENOVO-PC Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/8:15:28:21 user LENOVO-PC Install Universal C Runtime (KB3118401) Succeeded
2017/3/8:15:28:21 user LENOVO-PC Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/3/8:15:28:49 user LENOVO-PC Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/3/8:15:28:49 user LENOVO-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\user\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/8:15:28:57 user LENOVO-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/3/8:15:28:57 user LENOVO-PC Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/3/8:15:29:29 user LENOVO-PC Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/VCRED...
2017/3/8:15:29:29 user LENOVO-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\user\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/8:15:29:31 user LENOVO-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/3/8:15:29:32 user LENOVO-PC Download Play DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/3/8:15:30:09 user LENOVO-PC Download Complete DIRECTX http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/DIREC...
2017/3/8:15:30:09 user LENOVO-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/8:15:30:27 user LENOVO-PC Install DirectX Runtime Succeeded
2017/3/8:15:30:28 user LENOVO-PC Download Play CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/3/8:15:43:29 user LENOVO-PC Download Aborted CM http://efulfillment.autodesk.com/NET17SWDLD/2017/ACD/WI/{2753B039-2B44-4D22-BDD3-99B5E6409403}/CM.ta...
2017/3/8:15:43:29 user LENOVO-PC Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/8:15:43:30 user LENOVO-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/8:15:43:30 user LENOVO-PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/3/8:15:43:30 user LENOVO-PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/3/8:15:43:31 user LENOVO-PC PageOpen InstallCompleteDialog
2017/3/8:16:23:35 user LENOVO-PC === Setup ended ===
Çözüldü! Çözüme gidin.
TuncayBAKKAL01 tarafından çözüldü. Çözüme gidin.
Merhaba,
Kurulum esnasında Malzeme kitaplığı internet üzerinden indirilmeye çalışılırken hata alıyor. Bunun yerine aşağıdaki linkten offline dosyaları indirip kurulum yapmanızı öneririm.
Web kurulumunda bazen bu gibi hatalar ile karşılabiliniyor. Autodesk Virtual Agent ile kurulum yapmanızı öneririz. Download Links üzerinden istediğiniz yazılımı bilgisayarınıza sorunsuz indirip kurulum işlemi gerçekleştirebilirsiniz.
http://autodesk.creativevirtual15.com/autodesk/bot
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
