Yeni bilgisayar aldım, önceki bilgisayarımda öğrenci sürümü vardı AUTOCAD 2016 nın. Çok defa farklı internetlere bağlanarak da yüklemeye çalıştım ama her seferinde '"Installation complete. Some products failed to install.' diye uyarı veriyor ve yüklemiyor. Karşıma çıkan ekranda şöyle,, lütfen yardımcı olabilir misiniz?
2017/3/17:16:06:20 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/17:16:06:20 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AI2CFD.tmp
2017/3/17:16:06:22 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/17:16:06:20 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/17:16:06:20 zeynep DESKTOP-LU7M34O Launch
2017/3/17:16:06:21 zeynep DESKTOP-LU7M34O Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2017/3/17:16:06:21 zeynep DESKTOP-LU7M34O Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2017/3/17:16:06:21 zeynep DESKTOP-LU7M34O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\zeynep\AppData\Local\Temp\_AI2CFD.tmp\Setup\AcSetup.dll
2017/3/17:16:06:21 zeynep DESKTOP-LU7M34O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/17:16:06:21 zeynep DESKTOP-LU7M34O PageOpen LaunchDialog
2017/3/17:16:06:26 zeynep DESKTOP-LU7M34O PageOpen LicenseDialog
2017/3/17:16:06:26 zeynep DESKTOP-LU7M34O PageOpen ProductInfoDialog
2017/3/17:16:06:26 zeynep DESKTOP-LU7M34O PageOpen ProductSelectionDialog2
2017/3/17:16:06:28 zeynep DESKTOP-LU7M34O PageOpen FullProgressDialog
2017/3/17:16:06:29 zeynep DESKTOP-LU7M34O Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/17:16:06:29 zeynep DESKTOP-LU7M34O Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/17:16:06:29 zeynep DESKTOP-LU7M34O Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2017/3/17:16:06:29 zeynep DESKTOP-LU7M34O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/17:16:06:32 zeynep DESKTOP-LU7M34O Install DirectX Runtime Succeeded
2017/3/17:16:06:32 zeynep DESKTOP-LU7M34O Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2017/3/17:16:06:32 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/17:16:06:40 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 Succeeded
2017/3/17:16:06:40 zeynep DESKTOP-LU7M34O Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2017/3/17:16:06:40 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/17:16:06:47 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/17:16:06:47 zeynep DESKTOP-LU7M34O Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:06:50 zeynep DESKTOP-LU7M34O Download User Pause CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:06:50 zeynep DESKTOP-LU7M34O Download Paused CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:06:52 zeynep DESKTOP-LU7M34O Download User Resume CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:08:51 zeynep DESKTOP-LU7M34O Download User Pause CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:08:51 zeynep DESKTOP-LU7M34O Download Paused CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:10:16 zeynep DESKTOP-LU7M34O Download User Resume CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:10:24 zeynep DESKTOP-LU7M34O Download Aborted CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:10:24 zeynep DESKTOP-LU7M34O Install Autodesk® Material Library 2016 - Advanced Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/17:16:10:29 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/17:16:10:38 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 Succeeded
2017/3/17:16:10:38 zeynep DESKTOP-LU7M34O Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/17:16:10:38 zeynep DESKTOP-LU7M34O PageOpen InstallCompleteDialog
2017/3/17:16:10:59 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/17:16:31:31 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/17:16:31:31 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/17:16:31:31 zeynep DESKTOP-LU7M34O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2017/3/17:16:31:31 zeynep DESKTOP-LU7M34O Launch
2017/3/17:16:31:31 zeynep DESKTOP-LU7M34O CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2017/3/17:16:31:31 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AI3C6F.tmp
2017/3/17:16:31:33 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AI3C6F.tmp
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Launch
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\zeynep\AppData\Local\Temp\_AI3C6F.tmp\Setup\AcSetup.dll
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/17:16:31:32 zeynep DESKTOP-LU7M34O PageOpen LaunchDialog
2017/3/17:16:31:36 zeynep DESKTOP-LU7M34O PageOpen LicenseDialog
2017/3/17:16:31:36 zeynep DESKTOP-LU7M34O PageOpen ProductInfoDialog
2017/3/17:16:31:36 zeynep DESKTOP-LU7M34O PageOpen ProductSelectionDialog2
2017/3/17:16:31:40 zeynep DESKTOP-LU7M34O PageOpen FullProgressDialog
2017/3/17:16:31:40 zeynep DESKTOP-LU7M34O Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/17:16:31:40 zeynep DESKTOP-LU7M34O Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/17:16:31:41 zeynep DESKTOP-LU7M34O Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2017/3/17:16:31:41 zeynep DESKTOP-LU7M34O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/17:16:31:44 zeynep DESKTOP-LU7M34O Install DirectX Runtime Succeeded
2017/3/17:16:31:44 zeynep DESKTOP-LU7M34O Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2017/3/17:16:31:44 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/17:16:31:52 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 Succeeded
2017/3/17:16:31:53 zeynep DESKTOP-LU7M34O Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2017/3/17:16:31:53 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/17:16:31:58 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/17:16:31:58 zeynep DESKTOP-LU7M34O Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:33:07 zeynep DESKTOP-LU7M34O Download User Pause CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:33:07 zeynep DESKTOP-LU7M34O Download Paused CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:33:14 zeynep DESKTOP-LU7M34O Download User Resume CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:33:32 zeynep DESKTOP-LU7M34O Download User Pause CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:33:32 zeynep DESKTOP-LU7M34O Download Paused CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:33:34 zeynep DESKTOP-LU7M34O Download User Resume CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:34:14 zeynep DESKTOP-LU7M34O Download Aborted CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/17:16:34:14 zeynep DESKTOP-LU7M34O Install Autodesk® Material Library 2016 - Advanced Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/17:16:34:20 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/17:16:34:28 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 Succeeded
2017/3/17:16:34:28 zeynep DESKTOP-LU7M34O Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/17:16:34:28 zeynep DESKTOP-LU7M34O PageOpen InstallCompleteDialog
2017/3/17:16:34:37 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/18:21:14:01 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/18:21:14:01 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/18:21:14:01 zeynep DESKTOP-LU7M34O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2017/3/18:21:14:01 zeynep DESKTOP-LU7M34O Launch
2017/3/18:21:14:01 zeynep DESKTOP-LU7M34O CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2017/3/18:21:14:01 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AI3C1A.tmp
2017/3/18:21:14:04 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AI3C1A.tmp
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Launch
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\zeynep\AppData\Local\Temp\_AI3C1A.tmp\Setup\AcSetup.dll
2017/3/18:21:14:02 zeynep DESKTOP-LU7M34O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:21:14:03 zeynep DESKTOP-LU7M34O PageOpen LaunchDialog
2017/3/18:21:14:10 zeynep DESKTOP-LU7M34O PageOpen LicenseDialog
2017/3/18:21:14:10 zeynep DESKTOP-LU7M34O PageOpen ProductInfoDialog
2017/3/18:21:14:10 zeynep DESKTOP-LU7M34O PageOpen ProductSelectionDialog2
2017/3/18:21:14:16 zeynep DESKTOP-LU7M34O PageOpen FullProgressDialog
2017/3/18:21:14:19 zeynep DESKTOP-LU7M34O Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/18:21:14:19 zeynep DESKTOP-LU7M34O Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/18:21:14:19 zeynep DESKTOP-LU7M34O Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2017/3/18:21:14:19 zeynep DESKTOP-LU7M34O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:21:14:38 zeynep DESKTOP-LU7M34O Install DirectX Runtime Succeeded
2017/3/18:21:14:38 zeynep DESKTOP-LU7M34O Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2017/3/18:21:14:38 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:21:15:00 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 Succeeded
2017/3/18:21:15:01 zeynep DESKTOP-LU7M34O Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2017/3/18:21:15:01 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:21:15:13 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/18:21:15:14 zeynep DESKTOP-LU7M34O Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/18:21:18:05 zeynep DESKTOP-LU7M34O Download Aborted CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/18:21:18:05 zeynep DESKTOP-LU7M34O Install Autodesk® Material Library 2016 - Advanced Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/18:21:18:12 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/18:21:18:22 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 Succeeded
2017/3/18:21:18:22 zeynep DESKTOP-LU7M34O Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/18:21:18:22 zeynep DESKTOP-LU7M34O PageOpen InstallCompleteDialog
2017/3/18:21:19:13 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/19:22:08:04 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/19:22:08:04 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/19:22:08:04 zeynep DESKTOP-LU7M34O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2017/3/19:22:08:04 zeynep DESKTOP-LU7M34O Launch
2017/3/19:22:08:04 zeynep DESKTOP-LU7M34O CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2017/3/19:22:08:04 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AIA43F.tmp
2017/3/19:22:08:06 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AIA43F.tmp
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Launch
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\zeynep\AppData\Local\Temp\_AIA43F.tmp\Setup\AcSetup.dll
2017/3/19:22:08:05 zeynep DESKTOP-LU7M34O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/19:22:08:06 zeynep DESKTOP-LU7M34O PageOpen LaunchDialog
2017/3/19:22:08:11 zeynep DESKTOP-LU7M34O PageOpen LicenseDialog
2017/3/19:22:08:11 zeynep DESKTOP-LU7M34O PageOpen ProductInfoDialog
2017/3/19:22:08:11 zeynep DESKTOP-LU7M34O PageOpen ProductSelectionDialog2
2017/3/19:22:08:16 zeynep DESKTOP-LU7M34O PageOpen FullProgressDialog
2017/3/19:22:08:17 zeynep DESKTOP-LU7M34O Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/19:22:08:17 zeynep DESKTOP-LU7M34O Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/19:22:08:17 zeynep DESKTOP-LU7M34O Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2017/3/19:22:08:17 zeynep DESKTOP-LU7M34O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/19:22:08:36 zeynep DESKTOP-LU7M34O Install DirectX Runtime Succeeded
2017/3/19:22:08:36 zeynep DESKTOP-LU7M34O Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2017/3/19:22:08:37 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/19:22:08:47 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 Succeeded
2017/3/19:22:08:47 zeynep DESKTOP-LU7M34O Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2017/3/19:22:08:47 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/19:22:08:55 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/19:22:08:55 zeynep DESKTOP-LU7M34O Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/19:22:10:49 zeynep DESKTOP-LU7M34O Download Aborted CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/19:22:10:49 zeynep DESKTOP-LU7M34O Install Autodesk® Material Library 2016 - Advanced Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/19:22:10:56 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/19:22:11:06 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 Succeeded
2017/3/19:22:11:06 zeynep DESKTOP-LU7M34O Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/19:22:11:07 zeynep DESKTOP-LU7M34O PageOpen InstallCompleteDialog
2017/3/19:22:11:40 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/19:22:20:06 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/19:22:20:06 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/19:22:20:06 zeynep DESKTOP-LU7M34O Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2017/3/19:22:20:06 zeynep DESKTOP-LU7M34O Launch
2017/3/19:22:20:06 zeynep DESKTOP-LU7M34O CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2017/3/19:22:20:06 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AIA90C.tmp
2017/3/19:22:20:08 zeynep DESKTOP-LU7M34O === Setup ended ===
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O === Setup started on DESKTOP-LU7M34O by zeynep ===
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Path_Length: 154
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Current Directory C:\Users\zeynep\AppData\Local\Temp\_AIA90C.tmp
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Launch
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\zeynep\AppData\Local\Temp\_AIA90C.tmp\Setup\AcSetup.dll
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/19:22:20:07 zeynep DESKTOP-LU7M34O PageOpen LaunchDialog
2017/3/19:22:20:11 zeynep DESKTOP-LU7M34O PageOpen LicenseDialog
2017/3/19:22:20:11 zeynep DESKTOP-LU7M34O PageOpen ProductInfoDialog
2017/3/19:22:20:11 zeynep DESKTOP-LU7M34O PageOpen ProductSelectionDialog2
2017/3/19:22:20:41 zeynep DESKTOP-LU7M34O PageOpen FullProgressDialog
2017/3/19:22:20:42 zeynep DESKTOP-LU7M34O Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/19:22:20:42 zeynep DESKTOP-LU7M34O Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2017/3/19:22:20:42 zeynep DESKTOP-LU7M34O Download Skipped DIRECTX http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/DIRECTX.t...
2017/3/19:22:20:42 zeynep DESKTOP-LU7M34O Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/19:22:20:45 zeynep DESKTOP-LU7M34O Install DirectX Runtime Succeeded
2017/3/19:22:20:45 zeynep DESKTOP-LU7M34O Download Skipped CM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CM.tar.lz...
2017/3/19:22:20:45 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/19:22:20:55 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 Succeeded
2017/3/19:22:20:55 zeynep DESKTOP-LU7M34O Download Skipped CMILB http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMILB.tar...
2017/3/19:22:20:55 zeynep DESKTOP-LU7M34O Installing Autodesk Material Library 2016 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/19:22:21:00 zeynep DESKTOP-LU7M34O Install Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/19:22:21:01 zeynep DESKTOP-LU7M34O Download Play CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/19:22:22:54 zeynep DESKTOP-LU7M34O Download Aborted CMAIL http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CMAIL.tar...
2017/3/19:22:22:54 zeynep DESKTOP-LU7M34O Install Autodesk® Material Library 2016 - Advanced Image Library Failed Download Failed, Installation aborted, Result=1603
2017/3/19:22:22:59 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 - Base Image Library Succeeded
2017/3/19:22:23:07 zeynep DESKTOP-LU7M34O Rollback Autodesk Material Library 2016 Succeeded
2017/3/19:22:23:07 zeynep DESKTOP-LU7M34O Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Çözüldü! Çözüme gidin.
TuncayBAKKAL01 tarafından çözüldü. Çözüme gidin.
TArcok tarafından çözüldü. Çözüme gidin.
Merhabalar,
Autocad programını kurarken aldığını Microsof Visual ile ilgili hatalar gözüküyor.
Program ekle kaldır kısmında Microsof Visual C++ eski sürümlerini kaldırın.
Bilgisayar içerisindeki %Temp% klasöründeki dosyaları silin.
Temiz bir kurulum yaparak ilerleyebilirsiniz.
Autocad tabanlı bir hata değil.Pc nin işletim sistemi Microsoft Visual C++ ile ilgili Windows tabanlı bir hata olarak gözüküyor.
İyi Çalışmalar,Saygılarımla.
Merhaba
Web kurulumunda bazen bu gibi hatalar ile karşılabiliniyor. Autodesk Virtual Agent ile kurulum yapmanızı öneririz. Download Links üzerinden istediğiniz yazılımı bilgisayarınıza sorunsuz indirip kurulum işlemi gerçekleştirebilirsiniz.
http://autodesk.creativevirtual15.com/autodesk/bot
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
