2017/3/1:00:52:36 ugur1102 ASUS === Setup started on ASUS by ugur1102 ===
2017/3/1:00:52:36 ugur1102 ASUS Path_Length: 152
2017/3/1:00:52:36 ugur1102 ASUS Current Directory C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM
2017/3/1:00:52:36 ugur1102 ASUS Launch
2017/3/1:00:52:36 ugur1102 ASUS CommandLine
2017/3/1:00:52:36 ugur1102 ASUS Current Directory C:\Users\UUR~1\AppData\Local\Temp\_AI6936.tmp
2017/3/1:00:52:53 ugur1102 ASUS === Setup ended ===
2017/3/1:00:52:47 ugur1102 ASUS === Setup started on ASUS by ugur1102 ===
2017/3/1:00:52:47 ugur1102 ASUS Path_Length: 152
2017/3/1:00:52:47 ugur1102 ASUS Current Directory C:\Users\UUR~1\AppData\Local\Temp\_AI6936.tmp
2017/3/1:00:52:47 ugur1102 ASUS Launch
2017/3/1:00:52:49 ugur1102 ASUS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\UUR~1\AppData\Local\Temp\_AI6936.tmp\Setup\AcSetup.dll
2017/3/1:00:52:49 ugur1102 ASUS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/1:00:52:53 ugur1102 ASUS PageOpen LaunchDialog
2017/3/1:00:52:57 ugur1102 ASUS PageOpen LicenseDialog
2017/3/1:00:53:02 ugur1102 ASUS PageOpen ProductInfoDialog
2017/3/1:00:59:47 ugur1102 ASUS PageOpen ProductSelectionDialog2
2017/3/1:00:59:53 ugur1102 ASUS PageOpen FullProgressDialog
2017/3/1:00:59:53 ugur1102 ASUS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\UUR~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/3/1:01:00:42 ugur1102 ASUS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/3/1:01:00:42 ugur1102 ASUS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\UUR~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/3/1:01:01:15 ugur1102 ASUS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/3/1:01:01:15 ugur1102 ASUS Installing DirectX Runtime: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/1:01:01:38 ugur1102 ASUS Install DirectX Runtime Succeeded
2017/3/1:01:01:38 ugur1102 ASUS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:01:02:07 ugur1102 ASUS Install Autodesk Material Library 2015 Succeeded
2017/3/1:01:02:07 ugur1102 ASUS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:01:02:33 ugur1102 ASUS Install Autodesk Material Library 2015 - Base Image Library Succeeded
2017/3/1:01:02:33 ugur1102 ASUS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:01:02:51 ugur1102 ASUS Install Autodesk Content Service Succeeded
2017/3/1:01:02:51 ugur1102 ASUS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:01:02:58 ugur1102 ASUS Install Autodesk Content Service Language Pack Succeeded
2017/3/1:01:02:58 ugur1102 ASUS Installing Microsoft Visual Basic Power Packs 10.0: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe" /q /l C:\Users\UUR~1\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2017/3/1:01:03:37 ugur1102 ASUS Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2017/3/1:01:03:39 ugur1102 ASUS Installing Autodesk® AutoCAD® Civil 3D® 2015: TRANSFORMS="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\x64\en-us\C3D\C3D.mst;C:\Users\UUR~1\AppData\Local\Temp\_AI6936.tmp\x64\C3D\C3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:01:04:07 ugur1102 ASUS Install Autodesk® AutoCAD® Civil 3D® 2015 Failed Installation aborted, Result=1603
2017/3/1:01:04:07 ugur1102 ASUS Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2017/3/1:01:04:10 ugur1102 ASUS Rollback Autodesk Content Service Language Pack Succeeded
2017/3/1:01:04:19 ugur1102 ASUS Rollback Autodesk Content Service Succeeded
2017/3/1:01:04:35 ugur1102 ASUS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2017/3/1:01:05:03 ugur1102 ASUS Rollback Autodesk Material Library 2015 Succeeded
2017/3/1:01:05:03 ugur1102 ASUS Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/1:01:05:03 ugur1102 ASUS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2017/3/1:01:05:03 ugur1102 ASUS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
Çözüldü! Çözüme gidin.
TuncayBAKKAL01 tarafından çözüldü. Çözüme gidin.
Merhaba
Kurulum esnasında 1603 hatası vermiş bu hatanın kesin bir sebebi yok ama şu işlemleri yaparak düzeltebilirsiniz
bu işlemleri yaptıktan sonra tekrar deneyin
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
2017/3/1:18:30:39 ugur1102 ASUS === Setup started on ASUS by ugur1102 ===
2017/3/1:18:30:39 ugur1102 ASUS Path_Length: 152
2017/3/1:18:30:39 ugur1102 ASUS Current Directory C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM
2017/3/1:18:30:39 ugur1102 ASUS Launch
2017/3/1:18:30:39 ugur1102 ASUS CommandLine
2017/3/1:18:30:39 ugur1102 ASUS Current Directory C:\Users\UUR~1\AppData\Local\Temp\_AI12D6.tmp
2017/3/1:18:30:57 ugur1102 ASUS === Setup ended ===
2017/3/1:18:30:48 ugur1102 ASUS === Setup started on ASUS by ugur1102 ===
2017/3/1:18:30:48 ugur1102 ASUS Path_Length: 152
2017/3/1:18:30:48 ugur1102 ASUS Current Directory C:\Users\UUR~1\AppData\Local\Temp\_AI12D6.tmp
2017/3/1:18:30:48 ugur1102 ASUS Launch
2017/3/1:18:30:51 ugur1102 ASUS Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\UUR~1\AppData\Local\Temp\_AI12D6.tmp\Setup\AcSetup.dll
2017/3/1:18:30:51 ugur1102 ASUS Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/1:18:30:57 ugur1102 ASUS PageOpen LaunchDialog
2017/3/1:18:31:03 ugur1102 ASUS PageOpen LicenseDialog
2017/3/1:18:31:08 ugur1102 ASUS PageOpen ProductInfoDialog
2017/3/1:18:32:22 ugur1102 ASUS PageOpen ProductSelectionDialog2
2017/3/1:18:32:25 ugur1102 ASUS PageOpen FullProgressDialog
2017/3/1:18:32:25 ugur1102 ASUS Installing Microsoft Visual C++ 2012 Redistributable (x86) Update 4: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\UUR~1\AppData\Local\Temp\vcredist_x86_2012_UPD4.log
2017/3/1:18:32:29 ugur1102 ASUS Install Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Succeeded
2017/3/1:18:32:29 ugur1102 ASUS Installing Microsoft Visual C++ 2012 Redistributable (x64) Update 4: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\UUR~1\AppData\Local\Temp\vcredist_x64_2012_UPD4.log
2017/3/1:18:32:30 ugur1102 ASUS Install Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Succeeded
2017/3/1:18:32:30 ugur1102 ASUS Installing DirectX Runtime: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/1:18:32:39 ugur1102 ASUS Install DirectX Runtime Succeeded
2017/3/1:18:32:39 ugur1102 ASUS Installing Autodesk Material Library 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:18:32:50 ugur1102 ASUS Install Autodesk Material Library 2015 Succeeded
2017/3/1:18:32:51 ugur1102 ASUS Installing Autodesk Material Library 2015 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:18:33:09 ugur1102 ASUS Install Autodesk Material Library 2015 - Base Image Library Succeeded
2017/3/1:18:33:10 ugur1102 ASUS Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 4.5,Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:18:33:22 ugur1102 ASUS Install Autodesk Content Service Succeeded
2017/3/1:18:33:23 ugur1102 ASUS Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk AutoCAD Civil 3D 2015" SETUP_PACKAGECODE={A952A752-7057-47B0-AC57-5CE9AAD95CD4} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:18:33:26 ugur1102 ASUS Install Autodesk Content Service Language Pack Succeeded
2017/3/1:18:33:26 ugur1102 ASUS Installing Microsoft Visual Basic Power Packs 10.0: "C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\3rdParty\VBPowerPacks10\VisualBasicPowerPacksSetup.exe" /q /l C:\Users\UUR~1\AppData\Local\Temp\VisualBasicPowerPacks10Setup.log
2017/3/1:18:33:30 ugur1102 ASUS Install Microsoft Visual Basic Power Packs 10.0 Succeeded
2017/3/1:18:33:31 ugur1102 ASUS Installing Autodesk® AutoCAD® Civil 3D® 2015: TRANSFORMS="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\x64\en-us\C3D\C3D.mst;C:\Users\UUR~1\AppData\Local\Temp\_AI12D6.tmp\x64\C3D\C3D-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Civil_2015_R1_English_Win_64bit_DLM\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/1:18:33:43 ugur1102 ASUS Install Autodesk® AutoCAD® Civil 3D® 2015 Failed Installation aborted, Result=1603
2017/3/1:18:33:43 ugur1102 ASUS Rollback Microsoft Visual Basic Power Packs 10.0 Failed Failure is ignored, Result=1619
2017/3/1:18:33:46 ugur1102 ASUS Rollback Autodesk Content Service Language Pack Succeeded
2017/3/1:18:33:48 ugur1102 ASUS Rollback Autodesk Content Service Succeeded
2017/3/1:18:34:00 ugur1102 ASUS Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2017/3/1:18:34:19 ugur1102 ASUS Rollback Autodesk Material Library 2015 Succeeded
2017/3/1:18:34:19 ugur1102 ASUS Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/1:18:34:19 ugur1102 ASUS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Update 4 Failed Failure is ignored, Result=1619
2017/3/1:18:34:19 ugur1102 ASUS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Update 4 Failed Failure is ignored, Result=1619
DEDİKLERİNİZİ YAPTIM BU HATAYI VERDİ
Web kurulumunda bazen bu gibi hatalar ile karşılabiliniyor. Autodesk Virtual Agent ile kurulum yapmanızı öneririz. Download Links üzerinden istediğiniz yazılımı bilgisayarınıza sorunsuz indirip kurulum işlemi gerçekleştirebilirsiniz.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk
TuncayBAKKAL
AutoCAD Eğitmeni ve Danışmanı
AutoCAD ve Fusion 360 Görsel Eğitim
Fusion 360 Kitabı Çıktı!
http://www.tuncaybakkal.com
Instagram: @tuncay_bakkal
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudos") ile ödüllendirin.
zaten sizin paylaşmış olduğunuz link üzerinden autocad civil 2015 indirdim ve kurulumu yapamıyorum
Merhaba,
sisteminizde yüklü olan Microsoft Visual C++ uygulamasını kaldırın. sistemi yeniden başlattıktan sonra verdiğimiz linkten indirilen offline kurulum dosyasını çalıştırın. Bu aşama güvenlik duvarı ve antivirüs programlarını kapalı konuma getirin.
TuncayBAKKAL
Aradığınızı bulamadınız mı? Topluluğa sorun veya bilgilerinizi paylaşın.
