AutoCAD 2016 Yükleme Hatası
Uygulanamaz
1.938 Görüntüleme
8 Yanıt
Mesaj 1 / 9
Uygulanamaz
merhaba autocad 2016 yı yüklerken hata alıyorum yardımcı olur musunuz installation log file:
2018/11/1:00:05:44 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:05:44 ubell TULPAR Path_Length: 154
2018/11/1:00:05:44 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI9E54.tmp
2018/11/1:00:05:44 ubell TULPAR Launch
2018/11/1:00:05:45 ubell TULPAR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2018/11/1:00:05:45 ubell TULPAR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2018/11/1:00:05:45 ubell TULPAR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ubell\AppData\Local\Temp\_AI9E54.tmp\Setup\AcSetup.dll
2018/11/1:00:05:45 ubell TULPAR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/1:00:05:46 ubell TULPAR PageOpen LaunchDialog
2018/11/1:00:05:42 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:05:42 ubell TULPAR Path_Length: 154
2018/11/1:00:05:42 ubell TULPAR Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2018/11/1:00:05:42 ubell TULPAR Launch
2018/11/1:00:05:42 ubell TULPAR CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2018/11/1:00:05:42 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI9E54.tmp
2018/11/1:00:05:51 ubell TULPAR === Setup ended ===
2018/11/1:00:05:50 ubell TULPAR PageOpen LicenseDialog
2018/11/1:00:05:50 ubell TULPAR PageOpen ProductInfoDialog
2018/11/1:00:05:50 ubell TULPAR PageOpen ProductSelectionDialog2
2018/11/1:00:06:57 ubell TULPAR === Setup ended ===
2018/11/1:00:12:08 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:12:08 ubell TULPAR Path_Length: 154
2018/11/1:00:12:08 ubell TULPAR Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2018/11/1:00:12:08 ubell TULPAR Launch
2018/11/1:00:12:08 ubell TULPAR CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2018/11/1:00:12:08 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI83F9.tmp
2018/11/1:00:12:15 ubell TULPAR === Setup ended ===
2018/11/1:00:12:10 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:12:10 ubell TULPAR Path_Length: 154
2018/11/1:00:12:10 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI83F9.tmp
2018/11/1:00:12:10 ubell TULPAR Launch
2018/11/1:00:12:11 ubell TULPAR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2018/11/1:00:12:11 ubell TULPAR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2018/11/1:00:12:11 ubell TULPAR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ubell\AppData\Local\Temp\_AI83F9.tmp\Setup\AcSetup.dll
2018/11/1:00:12:11 ubell TULPAR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/1:00:12:12 ubell TULPAR PageOpen LaunchDialog
2018/11/1:00:12:19 ubell TULPAR PageOpen LicenseDialog
2018/11/1:00:12:19 ubell TULPAR PageOpen ProductInfoDialog
2018/11/1:00:12:19 ubell TULPAR PageOpen ProductSelectionDialog2
2018/11/1:00:12:23 ubell TULPAR PageOpen FullProgressDialog
2018/11/1:00:12:24 ubell TULPAR Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2018/11/1:00:12:26 ubell TULPAR Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2018/11/1:00:12:26 ubell TULPAR Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2018/11/1:00:12:26 ubell TULPAR Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/1:00:12:44 ubell TULPAR Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/1:00:12:44 ubell TULPAR PageOpen InstallCompleteDialog
2018/11/1:00:13:31 ubell TULPAR === Setup ended ===
2018/11/1:00:19:48 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:19:48 ubell TULPAR Path_Length: 154
2018/11/1:00:19:48 ubell TULPAR Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2018/11/1:00:19:48 ubell TULPAR Launch
2018/11/1:00:19:48 ubell TULPAR CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2018/11/1:00:19:48 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI883D.tmp
2018/11/1:00:19:54 ubell TULPAR === Setup ended ===
2018/11/1:00:19:50 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:19:50 ubell TULPAR Path_Length: 154
2018/11/1:00:19:50 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI883D.tmp
2018/11/1:00:19:50 ubell TULPAR Launch
2018/11/1:00:19:50 ubell TULPAR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2018/11/1:00:19:51 ubell TULPAR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2018/11/1:00:19:51 ubell TULPAR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ubell\AppData\Local\Temp\_AI883D.tmp\Setup\AcSetup.dll
2018/11/1:00:19:51 ubell TULPAR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/1:00:19:51 ubell TULPAR PageOpen LaunchDialog
2018/11/1:00:19:55 ubell TULPAR PageOpen LicenseDialog
2018/11/1:00:19:55 ubell TULPAR PageOpen ProductSelectionDialog2
2018/11/1:00:20:07 ubell TULPAR PageOpen FullProgressDialog
2018/11/1:00:20:07 ubell TULPAR Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/11/1:00:20:07 ubell TULPAR Install Network License Manager Succeeded
2018/11/1:00:20:09 ubell TULPAR Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2018/11/1:00:20:10 ubell TULPAR Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2018/11/1:00:20:10 ubell TULPAR Download Skipped CADM http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/CADM_x64_...
2018/11/1:00:20:10 ubell TULPAR Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2016" SETUP_PACKAGECODE={95CB8CCB-26D5-4C61-8F34-C6D922AB0D3C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,;;;;" PACKAGEUPI={F0736EFA-A11E-42C4-83B9-243BF2E8D69A} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2016" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/11/1:00:20:11 ubell TULPAR Install Autodesk CAD Manager Tools Succeeded
2018/11/1:00:20:11 ubell TULPAR Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2018/11/1:00:20:11 ubell TULPAR Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/1:00:20:27 ubell TULPAR Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2018/11/1:00:20:28 ubell TULPAR Rollback Autodesk CAD Manager Tools Succeeded
2018/11/1:00:20:28 ubell TULPAR Rollback Network License Manager Succeeded
2018/11/1:00:20:28 ubell TULPAR PageOpen InstallCompleteDialog
2018/11/1:00:20:38 ubell TULPAR === Setup ended ===
2018/11/1:00:23:53 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:23:53 ubell TULPAR Path_Length: 154
2018/11/1:00:23:53 ubell TULPAR Current Directory C:\Autodesk\AutoCAD_2016_English_Win_64bit_r1_wi_en-us
2018/11/1:00:23:53 ubell TULPAR Launch
2018/11/1:00:23:53 ubell TULPAR CommandLine /PK 001H1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/AutoCAD_2016_English_Win_64bit_r1_wi_en-us_Setup..."
2018/11/1:00:23:53 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI4303.tmp
2018/11/1:00:23:59 ubell TULPAR === Setup ended ===
2018/11/1:00:23:54 ubell TULPAR === Setup started on TULPAR by ubell ===
2018/11/1:00:23:54 ubell TULPAR Path_Length: 154
2018/11/1:00:23:54 ubell TULPAR Current Directory C:\Users\ubell\AppData\Local\Temp\_AI4303.tmp
2018/11/1:00:23:54 ubell TULPAR Launch
2018/11/1:00:23:55 ubell TULPAR Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUPMARK...
2018/11/1:00:23:55 ubell TULPAR Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/SETUP_x64...
2018/11/1:00:23:55 ubell TULPAR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\ubell\AppData\Local\Temp\_AI4303.tmp\Setup\AcSetup.dll
2018/11/1:00:23:55 ubell TULPAR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/11/1:00:23:56 ubell TULPAR PageOpen LaunchDialog
2018/11/1:00:24:01 ubell TULPAR PageOpen LicenseDialog
2018/11/1:00:24:01 ubell TULPAR PageOpen ProductInfoDialog
2018/11/1:00:24:01 ubell TULPAR PageOpen ProductSelectionDialog2
2018/11/1:00:24:04 ubell TULPAR PageOpen FullProgressDialog
2018/11/1:00:24:05 ubell TULPAR Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2018/11/1:00:24:06 ubell TULPAR Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/STARTMARK...
2018/11/1:00:24:07 ubell TULPAR Download Skipped VCREDIST2008SP1X86 http://edutrial.autodesk.com/NET16SWDLD/2016/ACD/WI/{14ECF31E-EBE5-406F-B7BA-627C489B2451}/VCREDIST2...
2018/11/1:00:24:07 ubell TULPAR Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2016\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2018/11/1:00:24:23 ubell TULPAR Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
0 Beğeni
1.939 Görüntüleme
8 Yanıt
Replies (8)
Mesaj 2 / 9
mehmetakiftoplu
Merhaba @Anonymous
Microsoft Visual C++ 2008 hatası gözüküyor bunun için aşıdaki linki kontrol edebilirsiniz
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/2011-Troubleshooting-Err...
Microsoft Visual C++ 2008 ' i yeniden kurmayı veya updatelerini kontrol edebilrsiniz..
İyi Çalışmalar.
Mehmet Akif TOPLU
Bu gönderiyi faydalı buldunuz mu? İşinize yaradıysa gönderiyi Beğenebilirsiniz.
Sorunuza tatmin edici bir cevap aldınız mı? Aldıysanız ÇÖZÜMÜ KABUL ET düğmesine tıklayın.
0 Beğeni
Mesaj 3 / 9
Uygulanamaz
Microsoft Visual C++ 2008 i sildim yeniden yükledim olmadı bütün Microsoft Visual sürümlerini sildim sadece Microsoft Visual C++ 2008 i yükledim yine aynı hatayı alıyorum yüklenmiyor
0 Beğeni
Mesaj 4 / 9
Gokhan_Kaya
Merhaba
size tavsiyem install now secenegi ile değilde Autodeskin sitesinden programı indirip kurmanızdır muhtemelen düzelecektir
diğer bir sebep ise Autocad 2016 zamanında olan c++ 201x ile şimdiki sp ile değiştiginden onun içinde ki yüklemeyi durdurur siz bilgisayarınızdakini kaldırıp deneyin
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudo") ile ödüllendirin.
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
0 Beğeni
Mesaj 5 / 9
Uygulanamaz
autodeskin sitesinden install now seçeneğinden yükledim siteye baktım başka türlü yükleme seçeneği göremedim Microsoft Visual in tüm sürümlerini silip de denedim sadece 2008 i silip de denedim hala aynı yüklenmiyor
0 Beğeni
Mesaj 6 / 9
Gokhan_Kaya
Merhaba @Anonymous
yükleme için girdiginiz internet sitesinde support bölümünden yazıp indirme linki rica edebilirisin. bu şekilde sıkıntını çözebilirsin
antivirus yazılımları ve güvenlik duvarını kapatıp denediniz mi ?
Gökhan Kaya
Tehcnical Manager
LinkedIn
Mesaj 7 / 9
Uygulanamaz
antivirüs ve güvenlik duvarını kapatıp da denedim olmuyor support tan link istedim bekliyorum
Mesaj 8 / 9
Gokhan_Kaya
Merhaba
2016 degilde 2019 kurmayı neden denemiyorsunuz log dosyasından edu lisansı kurdugunuz görünüyor 2019 için lisans sıkıntısı yok sanırım
destek muhtemelen size bir bilgi verecektir
Gökhan Kaya
Tehcnical Manager
LinkedIn
Mesaj 9 / 9
Uygulanamaz
okulda teknik resim dersinde 2016 sürümünü kullanıyoruz yoksa uğraşmazdım bu kadar yeni sürüm yüklemek daha mantıklı tabiki
0 Beğeni
