AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Main Table (ASD Concrete)
8 REPLIES 8
Message 1 of 9
mark.martin.se
2980 Views, 8 Replies
why is the first hook length missing in the main table? and, what's more important, why doesn't the program include this missing hook length in the total bar length cell?
Regards!
8 REPLIES 8
Message 2 of 9
jenyzosin
in reply to: mark.martin.se
hello,
The length of the hook is the same therefor is no need to represent that.
For the length of the bar check your setings (L=A+B)
There's a fine line between genius and insanity. I have erased this line - O.L.
Message 3 of 9
mark.martin.se
in reply to: jenyzosin
...can you be more specific! What settings L=A+B?
Regards!
Message 4 of 9
jenyzosin
Check this
Message 5 of 9
zcsillag
Use other software for RC detail :S
Regards
Csillag Zoltán
Message 6 of 9
jenyzosin
in reply to: zcsillag
ZCSILLAG i try a lots of software for RC detailing, but i tell you that ASD reinforcement (with all his bugs) i the best solution for me to detail reinforcement. I don't think is necessary to draw reinforcement 3D. All the world use 2D for many years and now, suddenly, is no good. I try Graitec, AllPlan and Tekla for reinforcement and his final drawing are execrable. This software is good because don't have 1000 popup windows for settings.
Here is an sample of drawings.
For steel dettailing I confess that Tekla is the best program, but I use ASD Steeel because this is the software with license.
 Asd Formwork is good, but you can't use it to transfer  your work to Revit or Robot to do the calclation. Only simple structure can be transfer to Revit (straight beams, columns and plane shells).
But I can tell you that's my opinion.
Message 7 of 9
mark.martin.se
Hi jenyzosin
....can you kindly printscreen your bar description settings since it seams that we work on a quite similar way!
This is another software (AutoCAD add-in) that I used to work with.
PS: I really don't want to complicate my life with 3D RC layouts.
Message 8 of 9
duchoabn
Dear Pro
What's software using for detail RC in your pdf file?
Thank so much
Message 9 of 9
mark.martin.se
in reply to: duchoabn
Hi,....
....my technician is working with:
http://www.radimpex.rs/about.php?id=2&lang=en
Regards!
”Boost
”Tips
