AutoCAD Versions in a Subscription
What versions of AutoCAD would I have access to with a subscription? Could I access 2018 if I purchased a subscription today?
Accepted Solutions (1)
jporter
Solution
Your Autodesk subscription provides you access to the current version plus three versions back.  If you purchased a subscription today you will have access to the 2022 software plus versions 2021, 2020, and 2019.
To answer your question directly. . .you will not have access to 2018 software if you purchase a subscription today.
Using AutoCAD as an example, when you login to your Autodesk account you will see you only have these options (as of today):
Answers (0)
