autocad 2016 can't run again
15 ANTWORTEN 15
GELÖST
Nachricht 3 von 16
fabebe09
595 Aufrufe, 15 Antworten
i reinstalled auto cad 2016 again, but when i tried to open the program, the pop up message again appeared saying window is searching for acad.exe. So the problem persist
15 ANTWORTEN 15
Nachricht 1 von 16
fabebe09
als Antwort auf: fabebe09
when i run autocad 2016 shortcut from desktop, the pop up message appears 'windows is searching for acad.exe.' and don't run the program
Nachricht 2 von 16
Sofia.Xanthopoulou
have you recently uninstalled AutoCAD? How?
Can you see in which path windows is trying to find the acad.exe? If yes, have you checked if there is any acad.exe?
This is the standard path.
For I don't know how you installed and on which OS, you better do a clean uninstall and reinstall the program.
You can use "Windows fix it" to get a clean result.
Please report back what you did and if your program is running now.
Thanks a lot
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Nachricht 4 von 16
Alfred.NESWADBA
crossposting ... why not continuing in the same thread >>>there<<<, I guess Sofia is waiting for feedback!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Nachricht 5 von 16
Sofia.Xanthopoulou
Hi @fabebe09,
any news on this topic? Please give us your feedback.
Tags (1)
Nachricht 6 von 16
Sofia.Xanthopoulou
Hi @fabebe09,
just saw your other post. Please continue the conversation here. The two posts will be merged.
Thank you
Nachricht 7 von 16
Sofia.Xanthopoulou
Have you installed the program as Administrator and started as such?
You never told me if the acad.exe is in the expected folder.
Regards
Nachricht 8 von 16
Sofia.Xanthopoulou
Hi @fabebe09,
If you don't get back to us it is impossible to support you on your issue. Please let us know if your problem still persists or if you have solved it and most important how you solved it.
Thanks a lot
Tags (1)
Nachricht 9 von 16
fabebe09
als Antwort auf: Sofia.Xanthopoulou
thanks much for your suggestions, i installed autocad 2016 twice by clean
uninstalling, after finished installation, when i tried to open the autocad
can't run, viewing the same message which i posted earlier, now i quit
trying to install again
Nachricht 10 von 16
fabebe09
I installed the program as administrator .......I didn' find the acad.exe file in autocad 2016 folder in hard disk 'c'
Nachricht 11 von 16
Sofia.Xanthopoulou
Please download the installation package again, seems that this is damaged.
Regards
Nachricht 12 von 16
Alfred.NESWADBA
Did you login as administrator or did you start the setup by right-click onto the exe and use option "start as administrator"?
Have you had disabled your antivirus system?
Do you have cleaning systems running (called like performance optimizers or tuning your system or something like that)?
- alfred -
Alfred NESWADBA
Nachricht 13 von 16
Sofia.Xanthopoulou
Hi @fabebe09,
any update here? Have you tried the suggested steps?
Regards
Tags (1)
Nachricht 14 von 16
fabebe09
Actually i installed two times, but the the problem persist
Nachricht 15 von 16
Sofia.Xanthopoulou
Have you downloaded another install package? Have you followed @Alfred.NESWADBA's advice?
I will not help to install and reinstall the program once the systems seems to be messed up. Please do some cleaning processes to get a fresh start. You can use Windows fix it.
Keep us updated about your progress.
Thank you
Nachricht 16 von 16
Sofia.Xanthopoulou
Hello @fabebe09,
I am wondering if you were able now to get your software running. Please let us know what you have done so far. Did you follow our advices?
Do you need assistance?
Regards
Tags (2)
