ACAD 2017 Fehlermeldung - Application does not support just-in-time (JIT)
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
cadgislabor
635 Aufrufe, 8 Antworten
ich habe auf mehreren Rechnern das englische Language Pack für AutoCAD2017x64 installiert und bekomme beim Programmstart folgende Fehlermeldung:
Unhandled exception has ocurred in a component in your application. If you Click Continue, the application will ignore this error and attempt to continue
Set connectionID threw an exception.
In den Details folgende Info:
debugging. See the end of this message for details.
************** Exception Text **************
System.Windows.Markup.XamlParseException: Set connectionId threw an exception. ---> System.InvalidCastException: Unable to cast object of type 'System.Windows.Controls.Grid' to type 'System.Windows.Controls.ContextMenu'.
   at Autodesk.AutoCAD.UserControls.DocumentSwitchControl.System.Windows.Markup.IComponentConnector.Connect(Int32 connectionId, Object target)
   at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetConnectionId(Object root, Int32 connectionId, Object instance)
   --- End of inner exception stack trace ---
   at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
   at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
   at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
   at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
   at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.CreateDocumentSwitchControl()
   at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.GetInstance()
   at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.PlaceDocumentSwitchControl()
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2053.0 built by: NET47REL1
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 21.0.0.0
    Win32 Version: 21.0.402.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
mscorlib.resources
    Win32 Version: 4.6.1055.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
    Win32 Version: 2015.11.2.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 2016.5.0.0
    Win32 Version: 2016.5.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
    Win32 Version: 21.0.52.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationUI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Windows.Forms
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcSeamless
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcSeamless.DLL
Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
AdMigLib
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdMigLib.DLL
AcSeamless.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
AcCustomize
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCustomize.DLL
AcCustomize.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCustomize.resources.DLL
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
Microsoft.Expression.Interactions
    Win32 Version: 2.0.20520.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Microsoft.Expression.Interactions.DLL
PresentationFramework-SystemCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information
Die Google suche hat mich auf diesen thread im englischsprachigen Forum geführt. Die dort gegebene Empfehlung das Communication Center abzuschalten habe ich ausprobiert. Das bringt nichts.
Wenn ich "Continue" klicke bricht AutoCAD mit dem Fehler FATAL ERROR: Unhalndled Access Violation Reading 0x0008 Exception at df8de1b4h ab.
Die deutschsprachige Version funtkioniert ohne Probleme. Das OS ist Windows7 x64 Professional mit aktuellsten Updates. AutoCAD ist ebenfalls.
Weiß da jemand weiter?
VG
Alex
@cadgislabor,
Die Themenüberschrift wurde zum besseren Verständnis editiert
von Sofia Xanthopoulou
8 ANTWORTEN 8
Nachricht 2 von 9
cadgislabor
als Antwort auf: cadgislabor
@Tarek_K Du hast den Thread von "Installation & Lizenzierung" hier her verschoben. Ich denke es müsste sich um ein Installationsproblem bzw. Kompatibilitätsproblem handeln.
Die Empfehlung von hier, .NET deinstallieren und wieder installieren (4.6.2, ebenso 4.6.1) hat nichts gebracht.
Nachricht 3 von 9
Tarek_K
Hallo @cadgislabor,
das ist korrekt, da du ja erst einmal schon alles insgesamt Installieren konntest und die Fehlermeldung nach der Installation aufgetreten ist, ist das Produktforum erst einmal der bessere Ort. 🙂 Wenn wir feststellen, dass es sich tatsächlich um ein Installationsproblem handelt, können wir es auch gerne entsprechend wieder in das andere Forum stellen.
Mit der Zielsetzung dir schnell zu helfen, habe ich es daher erst einmal (wegen - nach der Installation) in dieses Forum verschoben. 🙂
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Tarek Khodr
Nachricht 4 von 9
cadgislabor
Das Problem scheint häufiger vorzukommen als ich dachte und viele unterschiedliche Ursachen zu haben. Leider keine dabei die sich mit meinem Problem deckt.
Mittlerweile kann ich Grafikkartenprobleme ausschließen (Quadro 2000 und K2000 Treiber up to date).
sfc/scannow hat auch nicht geholfen.
Das Language Pack zu deinstallieren und wieder neu zu installieren brachte auch nichts.
Dann hab ich noch den Tip gefunden in den Internetexplorer Einstellungen die Häkchen bei  "Skriptdebuggin deaktivieren" rauszunehmen. Das war es auch nicht.
Jetzt gehen mir langsam die Ideen aus.
Ich hab Rechner, da ist das AutoCAD 2017 x64 language Pack schon länger drauf und es funktioniert. Gleiche Hardware!
Wesentlicher Unterschied zu jetzt: Zum Zeitpunkt der Installation aktuellere MS Updates und aktuellere AutoCAD Updates.
Nachricht 5 von 9
cadgislabor
Es deutet sich an, dass es an einem AutoCAD Update liegt.
Ich habe ein Image auf einen Rechner geladen da ist AutoCAD 2017 64-bit mit SP1 und das englische Language Pack drauf welches einwandfrei funktioniert. 1. Schritt AutoCAD deinstalliert. 2. mit einem Adminimage in dem das 2017.1.2 Update integriert wurde wieder installiert. Jetzt hat das englische Language Pack noch funktioniert. Aber als ich das Language Pack deinstalliert und wieder installiert habe da kam dann die selbe Fehlermeldung wie oben.
Das ganze passiert auch wenn man AutoCAD 2017 mit Update 2017.1.2 auf einem frischen Rechner installiert und dan das Language Pack drauf macht.
Zum Glück kann ich jetzt ausschließen, dass es an einem Windows Update liegt... das wär kniffliger geworden. Jetzt behelf ich mir erstmal damit dieses AutoCAD Update wieder rauszuhauen. Am Language Pack selber kann es nicht liegen. Da wurde am Adminimage nichts verändert.
Kann jemand mal versuchen das nachzustellen? @tobias_wiesendanger oder vielleicht @matthias.schindler?
VG
Alex
Nachricht 6 von 9
Sofia.Xanthopoulou
Hallo @cadgislabor,
das hört sich ja gemein an, was du da schilderst.
Du sagst also, dass AutoCAD 2017.1.2 installiert ist und dann ein Language Pack drauf kommt wird diese Fehlermeldung hervorgerufen? Aber wenn erst das LP drauf ist und dann das update funktioniert es?
Was ist, wenn du ohne das image installierst?
@cadgislabor, ich werde auf jeden Fall auf diesen Beitrag aufmerksam machen, damit es untersucht wird.
Bitte halte uns über jede Auffälligkeit auf dem Laufenden.
Tut mir leid, dass du diese Unannehmlichkeiten bekommen hast. Ich hoffe, wir werden schnell eine Erklärung dafür haben.
Danke dir für deinen Beitrag
LG
Nachricht 7 von 9
m_latz
Nachricht 8 von 9
Sofia.Xanthopoulou
als Antwort auf: m_latz
Hallo @cadgislabor,
nach weiterer Umfrage ist das Fazit, dass die "Schuldigen" unter C++, Java oder .Net zu suchen sind.
Dieser Link wurde mir gegeben. Würde das helfen? Schaltet die Meldung aus.
LG
Nachricht 9 von 9
cadgislabor
als Antwort auf: Sofia.Xanthopoulou
Die Lösung in dem Link von @m_latz funktioniert. Nach der Reparaturinstallation des ACAD 2017.1.2 Update funktioniert das englische Language Pack wieder. Und ich hab den verlinkten Thread nicht entdeckt, weil ich nach der englischsprachigen Fehlermeldung gesucht hab.... In dem geschilderten Fall war es genau umgekehrt.
@Sofia.Xanthopoulou das scheint also doch nichts mit irgend welchen Windows Komponenten zu tun zu haben.
Ist natürlich blöd, wenn die language Packs solche Fehler produzieren, wenn Updates installiert wurden. Von allein kommt doch keiner drauf erst AutoCAD zu installieren, dann das Language Pack und dann die Updates. Die Installationsdatei des language Packs müsste halt aktualisiert werden.
