Eu preciso de um comando que retorne o "ARRAY" depois de "Explodi-lo" , o último "Array" tinha dimensões diferentes e separadas mas era um corpo só. Tentei com "BO" mas, não é eficaz.
I need a command that returns the "ARRAY" after i "EXPLODE" it. I've used "BO" but it not work as well.
Solucionado! Ir para Solução.
Solucionado por TheCADnoob. Ir para Solução.
FYI :https://forums.autodesk.com/t5/portugues/ct-p/156
I'm not sure you can recreate the array after you explode it.
you could create a GROUP and move all the objects together.
CADnoob
HI,
>> I need a command that returns the "ARRAY" after i "EXPLODE" it. <<
i'm afraid that you can not do that.
It's not like "Recreate" the Array, but the started point.
i'll try to be more clearly...
Here, i need to change a layer of an "Old array"(Because i'm new on this work), so i'm trying to EXPLODE this array and change the layer inside the "Base array".
But, when i try to get togheter what i've done, i can't get all the things.
I would like to be more especific but it's too hard, being technical and te same time translate my thoughts to english.
GROUP can't fix my problem.
Thanks for helping, i try to be more especific, if you remember another command you can say. That will help me a lot
HI @ribeiro.eng,
Can you attach a sample drawing that shows what you are trying to accomplish? I am happy to take a look for you.
Perhaps edit source? This will allow you to edit the object that was used to create the array.
CADnoob
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
