Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Structural Steel Cut Member Edges (PlantSteelEdgeCut)
The  Cut Member Edges (PlantSteelEdgeCut) does a really nice job of automatically cleaning up a steel structure, however it fails to clean up corners. Please take this command a step further and clean up the corners where there are obvious Miter requirements when endpoints connect and the Members share the same plane. After the miters, Cut Backs are pretty obvious where the endpoint that is not on the same plane intersects the Miters.
